running ilogic form forms (exe)
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 8
I have this problem .. I have a lot of ilogic files i want to run form a forms (Exe).  but the problem is that all the ilogic files work .. if you run them ,,, or by aktivet form VBA Form... and run by marco .. but for some reason they do not work if I run them form  a form in exe program.  well some do ... but not all ...and it even not the same error that pops op
Private Sub Button3_Click(sender As Object, e As EventArgs) Handles Button3.Click
        Dim invApp As Inventor.Application
        invApp = GetObject(, "Inventor.Application")
        Dim addIn As ApplicationAddIn
        Dim addIns As ApplicationAddIns
        addIns = invApp.ApplicationAddIns
        For Each addIn In addIns
            If InStr(addIn.DisplayName, "iLogic") > 0 Then
                addIn.Activate()
                Dim iLogicAuto As Object
                iLogicAuto = addIn.Automation
                Exit For
        Next
        'Debug.Print(addIn.DisplayName)
        'Dim RuleName1 As String
        Dim EXTERNALrule
        EXTERNALrule = "Exportdatatocalworksheet"
        'Dim RuleName2 As String
        'INTERNALrule = "Rule2"
        Dim oDoc As Document
        oDoc = invApp.ActiveDocument
        If oDoc Is Nothing Then
            MsgBox("Missing Inventor Document")
            Exit Sub
        Dim iLogicAuto2 = addIn.Automation
        iLogicAuto2.RunExternalRule(oDoc, EXTERNALrule) 'for external rule
    End Sub
this code give me error
Current thread must be set to single thread apartment (STA)
I do not get it ... the Ilogic codes should be ok ... we have use them for a long time ... what i just need to do is hit a buttom and run a ilogic code in inventor .... can anyone tell me why that is soo hard?...and and  why some code run fine as normal ... som does not work
Replies (7)
Message 2 of 8
bradeneuropeArthur
is this Exe done with vb.net?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
bradeneuropeArthur
Try this piece of code:
        Dim addIn As ApplicationAddIn = Nothing
        Dim iLogicAuto As Object = Nothing
                addIn.Activate()
                ' Object
                Exit For
        Next
        Dim EXTERNALrule As String
        iLogicAuto.RunexternalRule(invApp.ActiveDocument, EXTERNALrule)
        Dim oDoc As Inventor.Document
            Exit Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 8
I am not 100% sure... i have select visual basic and add ref. Inventor.. and importe inventor at the top...
The funny thing is that some ilogic code.. runs and other does not..i am not sure why.. because all of the ilogic code works if they are run form inventor or using vba form form inventor vba editor
Message 5 of 8
please share the complete project
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 8
are you taking about the project in Microsoft Visual studio.. or also all the ilogic files as well ?
as far as i can see ... at lest 2 types of error ... one what is case then I type to change color of part/assembly .. and a other when I use excel(I also use copy Paste)
but the ilogic that change Enable prehighlight and the 2 code that Save JPG or Step file and one that try to reset browsernotes work ... might be more error or more that work ... but have not have time to test them all jet
Message 7 of 8
The Visual studio project folder.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 8
I just found out the the error is  cause be this line of code
Clipboard.SetText(oPreprice)
I use this code to copy an string to Clipboard (For Copy & paste).
