Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Resolve file by API
3 REPLIES 3
1809 Views, 3 Replies
Resolve file by API
I'm using Inventor 2017 and sometimes some files are not found.
Is it possible to solve the file through the API instead of using the Inventor command?
My idea is to create an API to automatically solve lost reference problems without the need of users intervention.
Thanks.
3 REPLIES 3
sajith_subramanian
Hi marcelo.zattera,
Please see below a piece of VBA code that does something similar. There could be better ways to achieve this, but hopefully this should help get you started.
Sub main()
    Dim assemdoc As AssemblyDocument
    Set assemdoc = ThisApplication.ActiveDocument
    Dim oCCs As ComponentOccurrences
    Dim occ As ComponentOccurrence
    Dim Path As String
    Dim Filename As String
    Dim FullFileName As String
    Dim Resolvedfile As String
    Set oCCs = assemdoc.ComponentDefinition.Occurrences
    Path = "C:\Temp\"   'The path which contains the unresolved file
    For Each occ In oCCs
      ' check for missing reference.
        If occ.ReferencedDocumentDescriptor.ReferenceMissing = True Then ' This will return true for unresolved and suppressed.
            FullFileName = occ.ReferencedDocumentDescriptor.FullDocumentName 'Get the full document name
            Filename = Right$(FullFileName, Len(FullFileName) - InStrRev(FullFileName, "\"))  ' Extract the filename from the full filename.
            Resolvedfile = ThisApplication.DesignProjectManager.ResolveFile(Path, Filename)  'Resolve file. Full file name is returned. Null will be returned if cannot be resolved.
            Call occ.Replace(Resolvedfile, False)  ' replace unresolved occurrence with the resolvedfile
        End If
    Next
End Sub
Do let me know if it works for you.
Sajith
Sajith Subramanian
Autodesk Developer Network
in reply to: sajith_subramanian
Thanks Sajith.
The example you sent helped a lot.
varad.keshatwar
@sajith_subramanian do you have any idea, how this can be done using
Apprentice Server
