Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to pick up center for circle VBA?
1 REPLY 1
AndreyBTRDQ2
58 Views, 1 Reply
Hello, kindly ask to help in code for making circle. I want to get a macros, that would create new sketch with project geometry from all existing sketches and would built a circle from a point, that i pick up by cursor. Radius of circle for example is 1 (in really i don't care on this stage, I just need to have method to choose center of this circle).  Thank you
1 REPLY 1
A.Acheson
in reply to: AndreyBTRDQ2
Hi @AndreyBTRDQ2
See one of the API samples here. The code below is the top half of the macro. I suggest if you need further helps with these sketches that you have a look through the samples. You will be able to identify a nice few methods for different objects.
    ' Create a new part document, using the default part template.
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
    ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
    ' Set a reference to the component definition.
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oPartDoc.ComponentDefinition
    ' Create a new sketch on the X-Y work plane.
    Dim oSketch As PlanarSketch
    Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
    ' Set a reference to the transient geometry object.
    Dim oTransGeom As TransientGeometry
    Set oTransGeom = ThisApplication.TransientGeometry
    Dim oCenter As Point2d
    Set oCenter = oTransGeom.CreatePoint2d(-5, 0)
    ' Create a sketch circle
    Dim oCircle As SketchCircle
    Set oCircle = oSketch.SketchCircles.AddByCenterRadius(oCenter, 1)
Regards
Alan
Technology Administrators
