Afternoon everyone!
I'm trying to find the code to rotate a drawing view and while I have found this snippet:
Dim oApp As Application
oApp = ThisApplication
Dim oActiveSheet As Sheet
oActiveSheet = oApp.ActiveDocument.Activesheet
Dim oBaseView As DrawingView
oBaseView = oActiveSheet.DrawingViews.Item(1)
'rotate by 45 degrees (converted from Radians)
'True = Clockwise
oBaseView.RotateByAngle(45*(PI / 180), True)
And while this does rotate the view, it cant rotate the view "Up" or "Down".
Does anyone know how to rotate a view on all different axis?
Solved by J-Camper. Go to Solution.
@C_Haines_ENG,
When you say rotate Up/Down, it sounds like you actually want to rotate the Camera of the view, not the 2D View. If this is correct, then something like this would work:
Sub Main
Dim PickView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a base view")
If IsNothing(PickView) Then Exit Sub ' If nothing gets selected then we're done
If PickView.ParentView IsNot Nothing Then Logger.Debug("Can only change the view cube of a base view") : Exit Sub
Dim ModelDoc As Document = PickView.ReferencedDocumentDescriptor.ReferencedDocument
If ModelDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject And ModelDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then Logger.Debug("Drawing view is not for a Part or assembly") : Exit Sub
Dim RotationAngle As Double = 45 'in degress [negative for opposite rotation
RotationAngle *= (Math.PI / 180) 'convert to radians
Dim RotationFromWorkAxis As WorkAxis = ModelDoc.ComponentDefinition.WorkAxes.Item(1) '1 = X axis, 2 = Y axis, 3 = Z axis
Dim RotationAxis As Vector = RotationFromWorkAxis.Line.Direction.AsVector 'Direction is a unitVector, so the Vector will have a length of 1, but that doesn't matter
Dim ViewCam As Camera = PickView.Camera
RotateCam(ViewCam, RotationAngle, RotationAxis, ViewCam.Target, ViewCam.UpVector)
End Sub
Sub RotateCam(Camera As Camera, ByVal offsetRad As Double, rotAxis As Vector, center As Point, upVector As UnitVector)
Dim Matrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix
Call Matrix.SetToRotation(offsetRad, rotAxis, center)
Dim newEye As Point = Camera.Eye
Call newEye.TransformBy(Matrix)
Camera.Eye = newEye
Camera.UpVector = upVector
Call Camera.ApplyWithoutTransition
End Sub
Let me know if you have any questions.
I decided to go a little further than a simple example:
Sub Main
'View Selection For Testing
'Setup
Dim TargetVector As Vector = ViewCam.Eye.VectorTo(ViewCam.Target)
TargetVector.Normalize()
Dim CamUpVector As Vector = ViewCam.UpVector.AsVector
CamUpVector.Normalize()
Dim UpPoint As Point = ViewCam.Eye.Copy
UpPoint.TranslateBy(CamUpVector)
Dim EyeTargetUpPlane As Plane = ThisApplication.TransientGeometry.CreatePlaneByThreePoints(ViewCam.Eye, ViewCam.Target, UpPoint)
Dim OtherVector As Vector = EyeTargetUpPlane.Normal.AsVector
OtherVector.Normalize
Dim RotationMatrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix()
Dim newEye As Point = ViewCam.Eye.Copy
'User input for rotation
'Angle
Dim UserInputRotationAngle As String = InputBox("How much to rotate? [Degrees expected]", "Rotation Angle", "45") 'in degress [negative for opposite rotation
Dim RotationAngle As Double = 0
Try
RotationAngle = Val(UserInputRotationAngle)
Catch
Logger.Debug("Could not convert the string: """ & UserInputRotationAngle & """ to a double")
Exit Sub
End Try
If RotationAngle = 0 Then Logger.Debug("0 was input, so no rotation needed.") : Exit Sub
'Direction
Dim OptionsList As New List(Of String)
OptionsList.AddRange({"Up", "Down", "Left", "Right", "Clockwise", "Counter-Clockwise" })
Dim UserInput As String = InputListBox("Which direction should the view rotate?", OptionsList, OptionsList.Item(0), "Rotation Direction")
Select Case UserInput
Case OptionsList.Item(0)
OtherVector.ScaleBy(-1) 'Invert axis for rotation
Call RotationMatrix.SetToRotation(RotationAngle, OtherVector, ViewCam.Target)
Call newEye.TransformBy(RotationMatrix)
Case OptionsList.Item(1)
Case OptionsList.Item(2)
Call RotationMatrix.SetToRotation(RotationAngle, CamUpVector, ViewCam.Target)
Case OptionsList.Item(3)
CamUpVector.ScaleBy(-1)'Invert axis for rotation
CamUpVector.ScaleBy(-1)'revert axis after rotation
Case OptionsList.Item(4)
TargetVector.ScaleBy(-1)'Invert axis for rotation
Call RotationMatrix.SetToRotation(RotationAngle, TargetVector, ViewCam.Target)
Call UpPoint.TransformBy(RotationMatrix)
CamUpVector = newEye.VectorTo(UpPoint)
Case OptionsList.Item(5)
Case Else
Logger.Debug("Un-handled option: " & UserInput)
Exit Sub
End Select
ViewCam.Eye = newEye
ViewCam.UpVector = CamUpVector.AsUnitVector
Call ViewCam.ApplyWithoutTransition
End Sub
