replacing a border and title block in an existing drawing ilogic
I have found an ilogic that works for me but when the drawing border and title block is the same name..it doesn't update!! probably because it thinks that its the same even though I have done the modification in our template file.
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 7995 StartFragment: 314 EndFragment: 7963 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
'delete sheet formats
ThisDrawing.ResourceFileName = "K:\Mech\INVENTOR2016\Inventor Resources\Templates\RAUTE_2016.dwg"
ThisDrawing.KeepExtraResources = True
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveEditDocument
Dim oCurrentNumber  As Sheet
oCurrentNumber = oDoc.ActiveSheet
' Iterate through the sheets, and delete the title blocks and symbols
Dim oSheet As Sheet
For Each oSheet In oDoc.Sheets
    oSheet.Activate
    Try
    oSheet.TitleBlock.Delete
    Catch
    'catch error if no border found
    End Try
    'set new border
    ActiveSheet.TitleBlock = "RAUTE A TITLE BLOCK"
    Try
    oSheet.Border.Delete
    Catch
    End Try
    'set new border
    ActiveSheet.Border = "RAUTE A-SIZE BORDER"
Next
'set back to original sheet
oCurrentNumber.Activate
what I end up doing is running this code first to rename the old blocks, what I want to do is to combine them... and delete the RAUTE A-SIZE BORDER-OLD
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 14307 StartFragment: 314 EndFragment: 14275 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
oDoc = ThisDoc.Document
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oTitleBlock As TitleBlock
oSheets = oDoc.Sheets
For Each oSheet In oSheets
    'handle errors
    'such as a sheet with no title block present
    On Error Resume Next
    'look at title blocks
    oTitleBlock = oSheet.TitleBlock
    For Each oTitleBlock In oDoc.TitleBlocks
        If oTitleBlock.Name = "RAUTE A TITLE BLOCK" Then
        'rename the instance of the sheet
        oTitleBlock.Name = "RAUTE A TITLE BLOCK-OLD"
        'also rename the definition in the Drawing Resources folder
            oTitleBlock.Definition.Name = "RAUTE A TITLE BLOCK-OLD"
        Else If oTitleBlock.Definition.Name = "RAUTE A TITLE BLOCK" Then
        'rename the definition in the Drawing Resources folder
               Else
        End If
        Next
    oBorder = oSheet.Border
    For Each oBorder In oDoc.Border
        If oBorder.Name = "RAUTE A-SIZE BORDER" Then
        oBorder.Name = "RAUTE A-SIZE BORDER-OLD"
            oBorder.Definition.Name = "RAUTE A-SIZE BORDER-OLD"
        Else If oBorder.Definition.Name = "RAUTE A-SIZE BORDER" Then
               Else
        End If
        Next
Next
 Thanks in advance for the help!
Replies (19)
bshbsh
What a coincidence, I was trying to do this yesterday and got stuck as well.
Replacing titleblocks with the copy of the new one from the template is easy. Just delete all titleblocks from all sheets so the definition is not referenced anywhere, then you can just delete the old definition, and copy the new one.
Borders are where I got stuck. I can not delete the definition because it is the DefaultBorder. I haven't found out yet how to "unset" this being the default and set the new one as the default instead through the API. Maybe the only way could be to edit it's sketch, remove everything, and copy over the new definition's sketch elements?
MechMachineMan
ProTip:
Trying to accomplish something with code? Try doing it manually through the UI first!
If you can't do it through the UI, it's ALMOST guaranteed you can't do it through the API.
Such is the case with trying to delete the default border.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
I would not use the default template if I were you..you should make your own custom then you will be able to replace delete..i have mine working now..but its like 3 different rules, I don't know how to combine it in one..but the first rules deletes sheet definitions, then replace borders new with old then 3rd rules deletes all the unused borders and title blocks.
Let me know if you want me to post these rules.
Joel
andrew_canfield
"3rd rule deletes all the unused borders and title blocks"
Could you share this please?
Regards
Andrew
Tony_Yates
Hi Try This:-
Sub Main()
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
Dim oBorder As Border = oSheet.Border
'Query Drawing Border insertion requirement
question = MessageBox.Show("Do you want to replace the existing drawing border with a new drawing border?", "Border Requirement", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
If question = vbYes Then
	DeleteBorders
	InsertBorder
	DeleteRevTable
	ActivateSheetOne
End If
End Sub
Sub DeleteBorders() 'this code deletes all the drawing sheet borders inthe active idw
'MessageBox.Show("deleteborder sub", "Title")
Dim oDrawDoc1 As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet1 As Sheet = oDrawDoc1.ActiveSheet
' Check to see if the sheet already has a border and delete it if it does.
For Each oSheet1 In ThisApplication.ActiveDocument.Sheets
	If Not oSheet1.Border Is Nothing Then
        oSheet1.Border.Delete
    End If
Next
End Sub
Sub InsertBorder() ' this code inserts a user selected drawing border on all drawing sheets in the active idw
'MessageBox.Show("insertborder sub", "Title")
'user slects a drawing border to insert
	Dim oDrawDoc3 As DrawingDocument = ThisApplication.ActiveDocument
	Dim oSheet3 As Sheet = oDrawDoc3.ActiveSheet
	Dim borderDef As BorderDefinition
	Dim strSelectedBorder As String = "Result2"
	Dim strBorderList As New ArrayList
	strBorderRequired = True
	Dim strDrawDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
	' change this file name & location to use a different
	ThisDrawing.ResourceFileName = "C:\Vault Workspace\Resources\Templates\your border.idw"
	Dim SourceFile = ThisDrawing.ResourceFileName
    Dim strSourceIDW As DrawingDocument
    strSourceIDW = ThisApplication.Documents.Open(SourceFile, False)
	For Each borderDef In strSourceIDW.BorderDefinitions
        strBorderList.Add(borderDef.Name)
    Next
	strSelectedBorder = InputListBox("Please select a border.", strBorderList, strSelectedBorder, "Border Selection", "Available Borders")
        If (StrComp(borderDef.Name, strSelectedBorder, vbTextCompare) = 0) Then
            CopyFrom = borderDef.CopyTo(strDrawDoc, True)
       	End If
	Next
	strSourceIDW.Close()
	Dim oNewBorderDef As BorderDefinition
	oNewBorderDef = oDrawDoc3.BorderDefinitions.Item(borderDef.Name)
	For Each oSheet3 In oDrawDoc3.Sheets
			oSheet3.AddBorder(oNewBorderDef)
	Next
End Sub
Sub DeleteRevTable() 'this code deletes the current rev table from the idw
'MessageBox.Show("rev table sub", "Title")
Dim oDrawDoc2 As Inventor.DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet2 As Sheet = oDrawDoc2.ActiveSheet
Dim oRevTable As RevisionTable = oSheet2.RevisionTables.Item(1)
Dim oDoc as Document = ThisDoc.Document
For Each oSheet2 in oDoc.Sheets
	If oSheet2.RevisionTables.Count>0 Then
		For Each  oRevTable In oSheet2.RevisionTables
		oRevTable.Delete
		Next
	End If
Next
End Sub
Sub ActivateSheetOne() 'makes drawing sheet 1 active in the idw
'MessageBox.Show("activesheet1 sub", "Title")
ActiveSheet = ThisDrawing.Sheet("Sheet:1")
End Sub
just change this  "C:\Vault Workspace\Resources\Templates\your border.idw" to your template location and name.
jmcgookin
@Tony_Yates This code is great for what I am currently trying to achieve. When I run this though, I do receive an error and not sure if the code is supposed to make the chosen border replacement active or if the user has to activate it manually. After the error, it does bring the new border into the drawing resources/Borders section but does not make it active. I would like some help on removing the user input box to select a border and have the code select the border on it's own. Meaning it will always be the same border from the reference file that I want to be the replacement in all idw files.
Error Info:
Error in rule: Plot With Plot Stamp #2 - iLogic Rule, in document: F-LA333-00001.idw
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.BorderDefinition.get_Name()
at ThisRule.InsertBorder()
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Any help would be very appreciated!
Jeremy
Tony_Yates
Hi Jeremy,
Delete the red text:-
	DeleteBorders
	InsertBorder
	'DeleteRevTable
	ActivateSheetOne
End If
ilya.galaktionov
Hi, Tony_Yates
I have the same Error, even after deleted the red text.
Is it possible to do the same code for Sketched Symbols?
I've tryied to change Borders to Sketched Symbols, but it failed.
I need onle insert Sketched Symbols from SourceFile
Tony_Yates
Add the name of your sketched symbol where ???? is.
Public Sub Main Sketchsymbol_Delete()
Dim oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oSketchedSymbolDef As SketchedSymbol
For Each oSketchedSymbolDef in oSheet.SketchedSymbols
If osketchedSymbolDef.Name = "????" Then
oSketchedSymbolDef.delete 'It will delete all the sketched symbols
End If
Next
Next
End Sub
ilya.galaktionov
If i Understand correctly, this code delete Symbols in opened drawing. I mean
Dim oSheet As Sheet
If osketchedSymbolDef.Name = "My symbols 1" Then
End If
If osketchedSymbolDef.Name = "My symbols 2" Then
End If
Next
Next
End Sub
I've tried to change previously code with border. see below. Is it Possible to use it? Could you please check
Sub Main()
Dim oSketchedSymbol As SketchedSymbol = oSheet.SketchedSymbol
	InsertSketchedSymbol
	ActivateSheetOne
End Sub
Sub InsertSketchedSymbol() ' this code inserts a user selected drawing SketchedSymbol on all drawing sheets in the active idw
'MessageBox.Show("insertSketchedSymbol sub", "Title")
'user slects a drawing SketchedSymbol to insert
	Dim SketchedSymbolDef As TitleBlockDefinition
	Dim strSelectedSketchedSymbol As String = "Result2"
	Dim strSketchedSymbolList As New ArrayList
	strSketchedSymbolRequired = True
	ThisDrawing.ResourceFileName = "C:\Inventor Working Area\Templates\Inventor\ØS\2020\Template.idw"
	For Each SketchedSymbolDef In strSourceIDW.SketchedSymbolDefinitions
        strSketchedSymbolList.Add(SketchedSymbolDef.Name)
    Next
	strSelectedSketchedSymbol = InputListBox("Please select a SketchedSymbol.", strSketchedSymbolList, strSelectedSketchedSymbol, "SketchedSymbol Selection", "Available SketchedSymbol")
        If (StrComp(SketchedSymbolDef.Name, strSelectedSketchedSymbol, vbTextCompare) = 0) Then
            CopyFrom = SketchedSymbolDef.CopyTo(strDrawDoc, True)
       	End If
	Next
	Dim oNewSketchedSymbolDef As SketchedSymbolDefinition
	oNewSketchedSymbolDef = oDrawDoc3.SketchedSymbolDefinitions.Item(SketchedSymbolDef.Name)
			oSheet3.AddSketchedSymbol(oNewSketchedSymbolDef)
	Next
End Sub
Dim oDoc As Document = ThisDoc.Document
For Each oSheet2 In oDoc.Sheets
		oRevTable.Delete
		Next
	End If
Next
End Sub
End Sub
ilya.galaktionov
I figured it out.
But if i use code for Delete and Insert Border i have error
Error Info:
Error in rule: InsertBorder - iLogic Rule, in document: MyDrawing.idw
at ThisRule.Main()
 i use
ub Main()
	DeleteBorders
	InsertBorder
	DeleteRevTable
	ActivateSheetOne
End Sub
    End If
Next
End Sub
	ThisDrawing.ResourceFileName = "C:\Inventor Working Area\Templates\Inventor\2020\MyTemplate.idw"
    Next
       	End If
	Next
	Next
End Sub
		oRevTable.Delete
		Next
	End If
Next
End Sub
End Sub
ilya.galaktionov
hi, could you please help me? how do create code “insert title block” for Active Sheet, not for all sheets of drawing. And when i use code i have massage “The template is opened”.I think it has to do with this line «strSourceClose ()”.   Else, i rewritten your code for Border to title block and when i use it, i can only insert one title block. Thank you!
blandb
I am more than likely missing something, but do the snippets not give you what you need??
Autodesk Certified Professional
ilya.galaktionov
Thank you!
I create this Code
ThisDrawing.ResourceFileName = "C:\Inventor Working Area\Templates\Inventor\MyTemplate.idw"
oDrawDoc = ThisDoc.Document
    'set new border
    ActiveSheet.TitleBlock = "My Title Block"
creggo
Getting the same error.  It's so close, but fails to insert the new border.
Any clever boffins can help with this one please? 🤞
   at ThisRule.Main()
AlexFielder
Hi @creggo,
Here is the updated rule I shared with you yesterday for the benefit of future searchers:
Option Explicit on
Sub Main()
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
	MessageBox.Show("This rule only works for Drawing Documents.", "Wrong Document Type", MessageBoxButtons.OK, MessageBoxIcon.Warning, MessageBoxDefaultButton.Button1)
	Exit Sub
End If
Dim question As DialogResult = MessageBox.Show("Do you want to replace the existing drawing border with a new drawing border?" _
& vbLf & "THIS CANNOT BE UNDONE!", "Border Requirement", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
	DeleteBorders
	InsertBorder
	DeleteRevTable
	ActivateSheetOne
End If
End Sub
Logger.Info("running delete borders")
    End If
Next
Logger.Info("finished running delete borders")
End Sub
	Dim strBorderRequired As Boolean = True
	ThisDrawing.ResourceFileName = "C:\Users\alex.fielder\OneDrive\Inventor\Designs\ManAndMachine\Templates\Standard.dwg"
    Next
	If strSelectedBorder = "Default Border" Then
		MessageBox.Show("Changing the Default Border border is NOT ALLOWED, exiting")
		logger.Error("User attempted to delete Default Border; this is not allowed by the API!")
		Exit Sub
	End If
	Dim NewBorder As BorderDefinition
        If (borderDef.Name = strSelectedBorder) Then
            NewBorder = borderDef.CopyTo(strDrawDoc, True)
			Exit For
       	End If
	Next
	oNewBorderDef = oDrawDoc3.BorderDefinitions.Item(NewBorder.Name)
	Next
End Sub
		For Each oRevTable As RevisionTable In oSheet2.RevisionTables
			oRevTable.Delete
		Next
	End If
Next
End Sub
End Sub
maarten_desmet
Hello!
I very much like this iLogic, but I would need an update on this.
Is there anybody that can help me with this?
I would like to have ALL borders and TITLEBLOCKS deleted in the .idw, then ALL borders and TITLEBLOCKS copy/paste into it. So not only the active ones on the sheet, but also the ones in the 'drawing resources'.
I assume, logicly the rule will have to delete the active ones on the sheet(s) and then delete the ones in the 'drawing resources'. After that a copy/paste from the template .idw.
I don't know if my question is clear, if not, please tell me what exactly.
Thank you for your help!
bshbsh
this is vba though and no error checking whatsoever, but you may get the idea. it's simple.
problem is you can't simply delete the default borderdefinition.
Public Sub borders()
    Dim InvDoc As Document
    Set InvDoc = ThisApplication.ActiveEditDocument
    Dim SourceDoc As Document
    Set SourceDoc = ThisApplication.Documents.Open("D:\Path\To\Your\IDW_Template_file.idw", False)
    For Each Sheet In InvDoc.Sheets
        If Not Sheet.TitleBlock Is Nothing Then Sheet.TitleBlock.Delete
        If Not Sheet.Border Is Nothing Then Sheet.Border.Delete
    Next
    For Each TitleBlockDefinition In InvDoc.TitleBlockDefinitions
        If TitleBlockDefinition.IsReferenced = False Then TitleBlockDefinition.Delete
    Next
    For Each BorderDefinition In InvDoc.BorderDefinitions
        If BorderDefinition.IsReferenced = False Then BorderDefinition.Delete
    Next
    For Each TitleBlockDefinition In SourceDoc.TitleBlockDefinitions
        Set TargetHeader = TitleBlockDefinition.CopyTo(InvDoc, True)
    Next
    For Each BorderDefinition In SourceDoc.BorderDefinitions
        Set TargetBorder = BorderDefinition.CopyTo(InvDoc, True)
        On Error GoTo 0
    Next
    SourceDoc.Close(True)
End Sub
WCrihfield
Hi @maarten_desmet.  This code is pretty much the same as the last VBA example, but is in iLogic, and does a couple minor things differently.  To use it, you would first need to edit the name of the drawing template file that you will be copying TitleBlockDefinitions & BorderDefinitions from.  And if you want the code to save the drawing after the changes have been made, just un-comment the last line of code.
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub
	Dim oDDoc As DrawingDocument = ThisDoc.Document
	Dim sTPath As String = ThisApplication.DesignProjectManager.ActiveDesignProject.TemplatesPath
	Dim sTFile As String = sTPath & "MyDrawingTemplate.idw"
	Dim oTemplate As DrawingDocument = ThisApplication.Documents.Open(sTFile, False)
	Dim oSheets As Inventor.Sheets = oDDoc.Sheets
	Dim oTrans As Inventor.Transaction
	oTrans = ThisApplication.TransactionManager.StartTransaction(oDDoc, "Update Borders & TitleBlocks")
	For Each oSheet As Inventor.Sheet In oSheets
		If oSheet.TitleBlock IsNot Nothing Then Try : oSheet.TitleBlock.Delete : Catch : End Try
		If oSheet.Border IsNot Nothing Then Try : oSheet.Border.Delete : Catch : End Try
	Next
	For Each oTBDef As TitleBlockDefinition In oDDoc.TitleBlockDefinitions
		If oTBDef.IsReferenced = False Then Try : oTBDef.Delete : Catch : End Try
	Next
	For Each oBDef As BorderDefinition In oDDoc.BorderDefinitions
		If oBDef.IsReferenced = False Then Try : oBDef.Delete : Catch : End Try
	Next
	For Each oBDef As BorderDefinition In oTemplate.BorderDefinitions
		Dim oNewBDef As BorderDefinition : Try : oNewBDef = oBDef.CopyTo(oDDoc, True) : Catch : End Try
	Next
	For Each oTBDef As TitleBlockDefinition In oTemplate.TitleBlockDefinitions
		Dim oNewTBDef As BorderDefinition : Try : oNewTBDef = oTBDef.CopyTo(oDDoc, True) : Catch : End Try
	Next
	oTrans.End
	oTemplate.Close(True)
	If oDDoc.RequiresUpdate Then oDDoc.Update2(True)
	'If oDDoc.Dirty Then oDDoc.Save2(False)
End Sub
Edit:  Just keep in mind that this code does not insert a new Border or TitleBlock on each sheet after the fact, because I do not know which Border & which TitleBlock you will want placed back into each sheet.  The actual working code I use at work is much longer than this, covers more than just borders & title blocks, and has a lot of customized stuff in it.  You will want to add more lines of code just before the "oTrans.End" line, to loop back through all of your drawing's sheets and add the border & title block you want to each sheet.
Wesley Crihfield
(Not an Autodesk Employee)
