- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Evening all
I have the attached code that I created (using lots of information from this forum) and it works well. Only issue I have is that when the code is run the 1st line of the label is always blank then the 2nd line will have the "View Label" and the 3rd line will have the scale. The scale is only entered if the scale is different to the base view scale.
The Code will also rename any section and detail view labels if one is skipped.
Can anyone point out why the 1st line is always blank???
Currently using Inventor 2022
