How to get parameter value of a sketch 3D point - GetParamAtPoint() does not work well?
liminma8458
liminma8458
Hi, experts,
It is a 3D spline in a sweep which has non-evenly distributed sketch points in it. I want to extract parameter values (in parameter space) of these sketch points. I try to use "CurveEvaluator.GetParamAtPoint Method". But It does not work through. See the code below and the part is attached.
Please help! Thank you very much!
Public Sub Curve_evaluator()
'On Error Resume Next
Dim oSpline3D As SketchSpline3D
Set oSpline3D = ThisApplication.CommandManager.Pick(kSketch3DCurveSplineFilter, "Select a sketch 3D Spline. Esc to quit.")
'----go through each point and get its parameter
Dim oFitPoint_Count As Integer
oFitPoint_Count = oSpline3D.FitPointCount
Dim oParam() As Double
ReDim oParam(1 To oFitPoint_Count) As Double
' Get the evaluator from the curve.
Dim oCurveEval As CurveEvaluator
'Set oCurveEval = oEdge.evaluator
Set oCurveEval = oSpline3D.Geometry.evaluator
' Get the parametric range of the curve.
Dim dMinParam As Double
Dim dMaxParam As Double
Call oCurveEval.GetParamExtents(dMinParam, dMaxParam)
Debug.Print vbCr & "dMinParam : " & dMinParam & vbCr & "dMaxParam : " & dMaxParam
Dim currentParam As Double
Dim i As Integer
For i = 1 To oFitPoint_Count
currentParam = dMinParam + ((dMaxParam - dMinParam) / oFitPoint_Count) * (i - 1)
Dim fst_point(2) As Double
Dim fst_param(0) As Double
Dim deviate_param(0) As Double
Dim sec_param(0) As Double
Dim sol_param(0) As SolutionNatureEnum
fst_param(0) = currentParam - 0.2
fst_point(0) = oSpline3D.FitPoint(i).Geometry.x
fst_point(1) = oSpline3D.FitPoint(i).Geometry.y
fst_point(2) = oSpline3D.FitPoint(i).Geometry.Z
'----There is problem with this line when runing---
Call oCurveEval.GetParamAtPoint(fst_point, fst_param, deviate_param, sec_param, sol_param)
oParam(i) = fst_param(0)
Debug.Print "currentParam: " & Format(currentParam, "0.00") & _
" first_param: " & Format(fst_param(0), "0.00") & _
" first_point: " & Format(fst_point(0), "0.00") & "," & _
Format(fst_point(1), "0.00") & "," & _
Format(fst_point(2), "0.00") & _
" second_param: " & Format(sec_param(0), "0.00") & _
" solution_no: " & Format(sol_param(0), "0.00")
Next i
End Sub
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
JelteDeJong
this is how i would do it in ilogic
Dim doc As PartDocument = ThisDoc.Document
Dim oSpline3D As SketchSpline3D = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketch3DCurveSplineFilter, "Select a sketch 3D Spline. Esc to quit.")
For i = 1 To oSpline3D.FitPointCount
    Dim sketchPoint3D As SketchPoint3D = oSpline3D.FitPoint(i)
    Dim geo As Point = sketchPoint3D.Geometry
    Logger.Info(String.Format("{0} - {1} - {2}", geo.X, geo.Y, geo.Z))
Next
Jelte de Jong
Blog: hjalte.nl - github.com
liminma8458
Hi, Jone,
I am not looking for the coordinate information of the sketch points. Instead, I am looking for the parameter value of these points in the parametric space on the spline edge. something like below:
Limin
YuhanZhang
:The output array needs not to be declared with size, so the code can be modified as below:
Set oCurveEval = oSpline3D.Geometry.Evaluator
Dim i As Integer
'Dim deviate_param(0) As Double
'Dim sec_param(0) As Double
'Dim sol_param(0) As SolutionNatureEnum
Dim deviate_param() As Double
Dim sec_param() As Double
Dim sol_param() As SolutionNatureEnum
fst_point(0) = oSpline3D.FitPoint(i).Geometry.X
fst_point(1) = oSpline3D.FitPoint(i).Geometry.Y
Next i
End Sub
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
liminma8458
Perfect! Thank you so much!
Limin
Stakin
Is there a way to get the BsplineCurve fitpointData of a BSplineSurface?
After obtain the BsplineCurve fitpointdata,is there a way to  recreate the SplineCurve in the sketch3d ?
