Reading and saving the mass of parts and assemblies
deak_peter
deak_peter
Hello everyone,
I have a question for you: does anyone have a sample code that saves the mass of all parts and subassemblies (they can include additional parts and assemblies) of an assembly in a .txt or .xlsx file?
To summarize, the mass of each part and assembly at each level of the assembly should be saved to a .txt or .xlsx file.
Thanks in advance
Peter
tyler.warner
@deak_peter you can try something like this to get you started. It will get the name & mass of every occurrence & all occurrences in the sub-assemblies. You can suppress line 25 if you only want the occurrences from the current assembly.
Class ThisRule
Public oFile As String = "C:/temp/testfile.txt"
	Sub Main
		If System.IO.File.Exists(oFile) Then
			Dim oResult As MsgBoxResult
			oResult = MsgBox("This file already exists. Would you like to overwrite it?", vbYesNo, "Overwrite File?")
			If oResult = vbYes Then
				System.IO.File.Delete(oFile)
			Else
				Exit Sub
			End If
        End If
		Dim oCompDef As Inventor.ComponentDefinition
		oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
		For Each oCompOcc As ComponentOccurrence In oCompDef.Occurrences
			If Not TypeOf oCompOcc.Definition Is VirtualComponentDefinition Then
				WriteTextToFile(oCompOcc.Name, iProperties.Mass(oCompOcc.Name), oFile, True)
				' Suppress the below line to only get the components in the open assembly.
				ProcessAllSubOcc(oCompOcc)
			End If
		Next
	End Sub
	Private Sub ProcessAllSubOcc(oCompOcc As ComponentOccurrence)
	    Dim oSubCompOcc As ComponentOccurrence
	    For Each oSubCompOcc In oCompOcc.SubOccurrences
			If Not TypeOf oSubCompOcc.Definition Is VirtualComponentDefinition Then
				If oSubCompOcc.SubOccurrences.Count = 0 Then
					WriteTextToFile(oSubCompOcc.Name, iProperties.Mass(oSubCompOcc.Name), oFile, True)
				Else
		        	ProcessAllSubOcc(oSubCompOcc)
				End If
			End If
	    Next
	End Sub
	Private Sub WriteTextToFile(oOccName As String, oMass As Double, oFile As String, oAppend As Boolean)
		Dim oText As String
		oText = oOccName & vbTab & vbTab & "Mass: " & oMass.ToString & vbCrLf
		My.Computer.FileSystem.WriteAllText(oFile, oText, oAppend)
	End Sub
End Class
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
WCrihfield
Hi @tyler.warner.  Just a quick note...  I would use 'vbCrLf' instead of 'vbNewLine' in any new codes you plan on using long term, because the 'vbNewLine' constant has been 'deprecated'.  Below is the link for that source/reference.
https://learn.microsoft.com/en-us/dotnet/api/microsoft.visualbasic.constants.vbnewline?view=net-7.0
They still compare equally in iLogic, but its best to make the switch sooner, rather than later.
Also, I believe he needs the solution to be in VBA, instead of iLogic/vb.net, because I have also been helping some though Private Messages.  Just so you know.  Nice code though.
Wesley Crihfield
(Not an Autodesk Employee)
deak_peter
Hi @tyler.warner
Thanks. I need to vba code. Maybe can you modify code?
tyler.warner
@deak_peter this will work for VBA.
Sub SumMassPropsToTXT()
    Dim Path As String
    Path = "C:/temp/testfile.txt"
    If Not Dir(Path, vbDirectory) = vbNullString Then
        Dim oResult As VbMsgBoxResult
        If oResult = vbNo Then
            Exit Sub
        End If
    End If
    Dim FileNumber As Integer
    FileNumber = FreeFile
    Open Path For Output As FileNumber
    Set oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    For Each oCompOcc In oCompDef.Occurrences
            Dim oMassProps As MassProperties
            Set oMassProps = oCompDef.MassProperties
            Call WriteTextToFile(Path, FileNumber, oCompOcc.Name, oMassProps.Mass)
            Call ProcessAllSubOcc(Path, FileNumber, oCompOcc)
        End If
    Next
    Close FileNumber
End Sub
Private Sub ProcessAllSubOcc(Path As String, FileNumber As Integer, ByVal oCompOcc As ComponentOccurrence)
            Set oMassProps = oSubCompOcc.MassProperties
                Call WriteTextToFile(Path, FileNumber, oSubCompOcc.Name, oMassProps.Mass)
            Else
                Call ProcessAllSubOcc(Path, FileNumber, oSubCompOcc)
            End If
        End If
    Next
End Sub
Private Sub WriteTextToFile(Path As String, FileNumber As Integer, oOccName As String, oMass As Double)
    Dim oText As String
    oText = oOccName & vbTab & vbTab & "Mass: " & oMass & vbCrLf
    Print #FileNumber, oText
End Sub
deak_peter
@tyler.warner
how to modify the code to write the data to an excel file?
For example:
Part name     Weight
Part1              1,563 kg
Part2              2,634 kg
Assembly1    4,642 kg
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
