Requesting, "For Each .... Next" type of code to access in sequence all iProperties in active document
I have parts and sub-assemblies with some custom iProperties created in them based on their location(s) in the main assembly hierarchy. These iProperties (self-created by an iLogic running in each assembly) carry information like part number of the parent assembly and quantity in the same assembly. Although these iProperties are different and not known (for different assemblies and parts) they have a regular pattern; i.e. one set starts from "QTY" and other set starts from "PA" which is useful to filter them from others.
In this document, I want to create another set of iProperty, say Qty01, Qty02,.. . where first Qty01 will be assigned the (first) or the value of any one of QTY_A000, QTY_A200, or QTY_A210, and secondly Qty02 will be assigned the (first of remaining) or the value of any one of the remaining QTY_A200, or QTY_A210, and so on.
Sample part (PT202) attached.
To achieve this, I need to access all iProperties of the current document in sequence. I request some one help me to get around this. This is very important in my research level of large scale assembly modelling.
Thanks.
Roy Wickrama, P. Eng.
Autodesk Inventor (Professional) - 2015
Autodesk Vault Basic - 2015
I'm not 100% sure what your end goal is. I'm a little confused how your intending to use the properties after you have collected them, however, here is a sample of code that would loop through all the custom iproperties as you have asked. Here I'm just printing the value to a messagebox where your logic would differ. Hopefully this at least answers that aspect of your request.
Dim oDoc As Document oDoc = ThisApplication.ActiveDocument Dim invCustomPropertySet As PropertySet invCustomPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties") For Each oProp As Inventor.Property In invCustomPropertySet MessageBox.Show(oProp.Value) Next
Looking at your request again, does this accomplish what you are setting out to do?
Dim oDoc As Document oDoc = ThisApplication.ActiveDocument Dim invCustomPropertySet As PropertySet invCustomPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties") Dim qtyCount As Integer Dim qtyString As String qtyCount = 1 For Each oProp As Inventor.Property In invCustomPropertySet 'MessageBox.Show(oProp.Name) If Left(oProp.Name,4) = "QTY_" Then 'MessageBox.Show(oProp.Name & ": " & oProp.Value) If qtyCount < 10 Then qtyString = "QTY0" & qtyCount Else qtyString = "QTY" & qtyCount End If Dim newProp As Inventor.Property Try newProp = invCustomPropertySet.Item(qtyString) Catch newProp = invCustomPropertySet.Add(oProp.Value,qtyString) End Try newProp.Value = oProp.Value qtyCount = qtyCount + 1 End If Next
