Property ID question
b.bosman
b.bosman
Hello helpfull people,
Is there somewhere a list like this
https://forums.autodesk.com/t5/inventor-programming-ilogic/get-set-iproperty-directly-with-id-enum/t...
but with more properties? We would like to use the ID for "Thickness" but we can not find it yet
Thanks in advance for all the help
bradeneuropeArthur
Thickness is not part of the Standard Inventor Properties.
Only if you export it in the ParameterBox, then it is available in the Custom Iproperties
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
b.bosman
Thats indeed the option which we use already to show up in our partslist. But now we have an add in to create an excel export which is created by property ID. In this way we cant acces the custom properties. So maybe I have to ask my question a little different. Is there a piece of code to extract the property ID from custom properties?
yuzeaa
Dim doc As Document = ThisDoc.Document
Dim oCustomPropset As PropertySet
oCustomPropset = doc.PropertySets.Item("Inventor User Defined Properties")
For Each oCustomProperty In oCustomPropset
	Logger.Info(oCustomProperty.name & " " & oCustomProperty.PropId)
Next
bradeneuropeArthur
Hi @b.bosman,
With this piece of I-logic code you can list all Iproperties including the Custom Iproperties.
Dim d As Document = ThisDoc.Document
Dim ps As PropertySet
Dim p As [Property]
 Try
FileNameTekstfile = "Iproperties"
MkDir("C:\templogs\Iproperties")
Catch ex As Exception
End Try
Dim FILE_NAME As String = "c:\templogs\Iproperties\ " & FileNameTekstfile & ".txt"
Dim objWriter As New System.IO.StreamWriter(FILE_NAME, True)
For Each ps In d.PropertySets
	objWriter.WriteLine(ps.DisplayName & vbTab & "-" & vbTab & ps.InternalName)
	For Each p In ps
		Try
                objWriter.WriteLine(p.Name & vbTab & "-" & vbTab & p.DisplayName & vbTab & "-" & vbTab & p.PropId)
            End Try
		Next
	Next
	objWriter.Close()
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
b.bosman
Thank you guys, this was very helpfull
