Prompt Entry Read needed in code.
BVasquez78MGR
BVasquez78MGR
I'm kind of new at coding. Can someone help me? Right now, my SHEET # is linked to the browser name. How do I attach the field text, SHEET #, to modify this code below?
This is the outcome I need to accomplish in the end.
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view.")
If oView IsNot Nothing Then
	If  oView.ViewType = DrawingViewTypeEnum.kDetailDrawingViewType Then
		oDView = oView
		oOrigName = oDView.Name
		oDView.Name = oOrigName & "/ MU-8005"
		oDView.Label.FormattedText = "DETAIL " & oOrigName & "<Br/>SCALE <DrawingViewScale/>"
	End If
	Else
		MsgBox("The selected View's Scale is set by the Base View, and can't be changed this way.", vbOKOnly + vbExclamation, " ")
	End If
Curtis_Waguespack
Hi @BVasquez78MGR
I think this will get what you are after.
I hope this helps.
Curtis
Dim oTBlock  As TitleBlock
oTBlock = oDDoc.ActiveSheet.TitleBlock
Dim oTBlockDef As TitleBlockDefinition
oTBlockDef = oTBlock.Definition
Dim oTextBox As TextBox
' Find the Prompted Entry called <MATERIALS> in the Title Block
For Each oTextBox_InTB_Def As TextBox In oTBlockDef.Sketch.TextBoxes
	'Logger.info(oTextBox_InTB_Def.Text)
    If oTextBox_InTB_Def.Text.Contains(UCase("SHEET #")) Then
        oTextBox = oTextBox_InTB_Def
		sValue = oTBlock.GetResultText(oTextBox)
		'MsgBox(sValue)
         Exit For
    End If
Next
		oDView = oView
		oDView.Name = oOrigName & "/ " & sValue
	End If
Else
End If
BVasquez78MGR
You are awesome, Obi-Wan Kanobi 😊;  it worked great!! It will be a lot more challenging to figure out how to reference another detail section with the same label from another page, which will be my next headache. Trying to use the same approach, pick a view and copy info to the new section view. Do you think this can be possible?
Curtis_Waguespack
Hi @BVasquez78MGR
I didn't test it, but I think you would do something along these lines.
I hope this helps.
Curtis
		'MsgBox(sValue)
         Exit For
    End If
Next
		oDView = oView
	End If
Else
End If
Dim oSheet As Sheet
For Each oSheet In oDDoc.Sheets
	For Each oView In oSheet.DrawingViews
		If oView.Type = DrawingViewTypeEnum.kDetailDrawingViewType
			If oView.Name.Contains(oOrigName) Then
				oView.Name = oOrigName & "/ " & sValue
			End If
		End If
	Next
Next
