I have an iLogic rule that I use while in an assembly edit of a part. With the part in edit mode, I run this rule and I can select a face on the part and then it will create a sketch on that face and it projects the cut edges of all parts touching that face. It works pretty well but it will not project the cut edges of a part that is touching the face if the part is in a sub-assembly. For example, maybe I edit part 53 in my U assembly and run this rule. It will detect and project cut edges of parts found within the U assembly, however, if there is a sub-assembly in the U assembly like UQ and one of the parts in UQ is touching the part face, it will not project cut edges of that part. Any ideas on how to also include parts touching the part sketch face if they are in a sub-assembly? Below is my code to test. Run it while editing a part in an assembly
Public Sub Main()
' Declare the application object and get the current application
Dim oApp As Inventor.Application = ThisApplication
Dim oDoc As Inventor.Document = oApp.ActiveDocument
Dim oAssDoc As Inventor.AssemblyDocument = oApp.ActiveDocument
Dim oAssDocDef As Inventor.AssemblyComponentDefinition = oAssDoc.ComponentDefinition
Dim oFaceProxy As FaceProxy = Nothing
Dim oSketch As PlanarSketch = Nothing
Try
' Prompt user to select a face
oFaceProxy = oApp.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Pick a face")
If oFaceProxy Is Nothing Then
MessageBox.Show("No face was selected.")
Return
End If
Catch ex As Exception
MessageBox.Show("Error in selecting face: " & ex.Message)
Return
End Try
' Define an empty list to hold occurrences touching the selected face
Dim oOccurrenceListA As New List(Of ComponentOccurrence)
Try
' Iterate through the occurrences in the assembly to find parts touching the selected face
For Each oOccurrence As ComponentOccurrence In oAssDocDef.Occurrences
' Check each occurrence against the selected face to find touching parts
If oApp.MeasureTools.GetMinimumDistance(oOccurrence, oFaceProxy) < 0.01 AndAlso Not oOccurrence Is oFaceProxy.ContainingOccurrence Then
oOccurrenceListA.Add(oOccurrence)
End If
Next
MessageBox.Show("Error finding touching parts: " & ex.Message)
Return
End Try
' Check if any parts are touching the selected face
If oOccurrenceListA.Count = 0 Then
' If no parts are touching, notify the user and exit the sub
MessageBox.Show("No parts touching the selected face. No scribe lines will be created.", "No Parts Touching")
Return
End If
Try
' Set the default sketch name
Dim defaultSketchName As String = "SCRIBE LINES"
' Access the occurrence containing the face
Dim oOcc As ComponentOccurrence = oFaceProxy.ContainingOccurrence
' Access the part document's component definition
Dim oMainPartDef As PartComponentDefinition = oOcc.Definition
' Initialize the sketch variable with the unique name
oSketch = oMainPartDef.Sketches.Add(oFaceProxy.NativeObject)
oSketch.Name = defaultSketchName
oSketch.Edit() ' Start the sketch editing mode
MessageBox.Show("Error initializing sketch: " & ex.Message)
Return
End Try
' Check if the sketch was created successfully
If oSketch Is Nothing Then
MessageBox.Show("Failed to create sketch.")
Return
End If
'Begin projecting cut edges on sketch
Try
' Start a transaction to project cut edges
Dim oTrans As Transaction = oApp.TransactionManager.StartTransaction(oDoc, "Project Cut Edges")
Dim oControlDef As ControlDefinition = oApp.CommandManager.ControlDefinitions.Item("SketchProjectCutEdgesCmd")
oApp.ActiveDocument.SelectSet.Clear() ' Clear current selection
For Each oOcc In oOccurrenceListA
oApp.ActiveDocument.SelectSet.Select(oOcc)
Next
oControlDef.Execute() ' Execute the command
oTrans.End() ' Commit the transaction
MessageBox.Show("Error projecting cut edges: " & ex.Message)
Finally
oApp.CommandManager.StopActiveCommand() ' Ensure no command is left active
End Try
' Exit the sketch
Try
oSketch.ExitEdit() ' Exit the sketch editing mode
MessageBox.Show("Error exiting the sketch: " & ex.Message)
End Try
' Final update and clear selection
oApp.ActiveDocument.Update2(True)
End Sub
