Problem setting part name to form
dialunau
dialunau
Hello everyone,
I'm trying to set the name of a selected part occurrence into a radiobutton of a form.
I'm using a shared variable to get the name from another rule. Everything works well, but in the end the name of the occurrence is missing in the form.
Does anyone know how to get the string I want into the form?
My code looks like this:
AddReference "System.Drawing"
Imports System.ComponentModel
Imports System.Drawing
Imports System.Windows.Forms
Public Sub Main()
	'//////// GET THE OCCURRENCE NAME ////////
	Dim oOcc As String = SharedVariable("Occurrence")
	'//////// RUN THE FORM ////////
	Dim oForm As New WinForm
	oForm.Show
End Sub
Public Class WinForm
	Inherits System.Windows.Forms.Form
	Public oLargerFont As System.Drawing.Font = New Font("Arial", 10)
	'//////// CREATE NEW INSTANCE ////////
	Public Sub New
		oForm = Me
		'//////// PARAMETERS FOR THE FORM ////////
		With oForm
			.FormBorderStyle = FormBorderStyle.FixedToolWindow
			.StartPosition = FormStartPosition.CenterScreen
			.Width = 300
			.Height = 700
			.TopMost = True
			.Font = oLargerFont
			.Text = "Component Select"
			.Name = "Components"
			.ShowInTaskbar = False
		End With
		Dim oButton1 As New Button()
		With oButton1
			.Text = "MODIFY"
			.Top = 25
			.Left = 25
			.Enabled = True
			.AutoSize = True
		End With
		oForm.Controls.Add(oButton1)
		AddHandler oButton1.Click, AddressOf oButton1_Click
		Dim oOptions As New List(Of String)
		oOptions.AddRange({"Option 1","Option 2","Option 3"})
		Dim oGroupBox As GroupBox = New GroupBox()
		oGroupBox.Left = 25
		oGroupBox.Width = 150
		oGroupBox.Top = oButton1.Bottom + 20
		oGroupBox.Height = 100
		oGroupBox.Text = "Choose"
		oForm.Controls.Add(oGroupBox)
		'//////// RADIOBUTTON PARAMETERS ////////
		Dim oRadioButton1 As New RadioButton()
		oGroupBox.Controls.Add(oRadioButton1)
		oRadioButton1.Text = oOcc.Name
		oRadioButton1.Top = 20
		oRadioButton1.Left = 35
		oRadioButton1.AutoSize = True
	End Sub
	Private Sub oButton1_Click(ByVal oSender As System.Object, ByVal oEventArgs As System.EventArgs)
		MsgBox("Action triggered",vbOKOnly+vbInformation,"EVENT FEEDBACK")
	End Sub
End Class
JelteDeJong
try it this way:
Public Sub Main()
	Dim occ As ComponentOccurrence = ThisApplication.CommandManager.Pick(
			SelectionFilterEnum.kAssemblyOccurrenceFilter,
			"Select occurrence")
	Dim occName As String = occ.Name
	Dim oForm As New WinForm(occName)
	oForm.Show
End Sub
	Public Sub New(occName As String)
		oForm = Me
		With oForm
			.Width = 300
			.Height = 700
			.TopMost = True
			.Font = oLargerFont
		End With
		With oButton1
			.Text = "MODIFY"
			.Top = 25
			.Left = 25
			.Enabled = True
			.AutoSize = True
		End With
		oGroupBox.Left = 25
		oRadioButton1.Text = occName
	End Sub
	End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
dialunau
That is exactly what I needed to work with the variable inside the class.
Thank you.
