Number of Each Reference Document -- Part Quantity
dalton98
dalton98
Hello. I'm trying to write a code that gives me the number of each specific part in my assembly.
The obvious answer is to look at the BOM, but I want it to use the reference documents like the rest of my code.
This is kind of what I want, but it gives the total number of parts in the assembly.
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisDrawing.ModelDocument
    ' Get the assembly component definition.
    Dim oAsmDef As AssemblyComponentDefinition
    oAsmDef = oAsmDoc.ComponentDefinition
    ' Get all of the leaf occurrences of the assembly.
    Dim oLeafOccs As ComponentOccurrencesEnumerator
    oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
    ' Iterate through the occurrences and print the name.
	Dim cnt As Integer
	cnt = 0
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oLeafOccs
        If oOcc.BOMStructure = BOMStructureEnum.kNormalBOMStructure Then
			cnt = cnt + 1
			MessageBox.Show(oOcc.Name)
    Next
	MessageBox.Show(cnt)
vpeuvion
You can try this.
	Dim oOccList As New List(Of String)
	Dim oQtyList As New List(Of Integer)
			If Not oOccList.Contains(oOcc.Name.Split(":")(0)) Then
				oOccList.Add(oOcc.Name.Split(":")(0))
				oQtyList.Add(1)
			Else
				Dim LastQty As Integer = oQtyList.Item(oOccList.IndexOf(oOcc.Name.Split(":")(0)))
				oQtyList.Item(oOccList.IndexOf(oOcc.Name.Split(":")(0))) = LastQty + 1
    Next
	Dim Results As String =  Nothing
	For i = 0 To oOccList.Count-1
		Results = Results & oOccList.Item(i) & " : " & oQtyList.Item(i) & Chr(13)
	Next
	MessageBox.Show(Results)
 Hope this can help you.
Vincent.
