Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Place with iMates Angle
0 REPLIES 0
Message 1 of 1
Cadkunde.nl
56 Views, 0 Replies
I'm trying to make placement of standard components easier for a company
I've added 3 iMates:
- centerline mate (centerline at end of conveyorbelt)
- midplane mate
- Groundplane Angle
Centerline fixes position, leaving axial and radial movement
Midplane blocks axial movement
Then angle blocks radial movement
When I do it without adding the 3 iMates to an iComposite:
When I add the 3 iMates to an iComposite and place the components in an assembly using iMates:
Looking at the iMate properties in the assembly:
Looking at the imate properties inside the parts:
When using iComposite, it is undirected, and if I press "G" for free move, I can rotate the part and then it snaps correctly: Confirming solution = undirected.
There is no option in iMate to choose directed or undirected, and when I look in the iMate, it says directed.
Plz autodesk tell me what is going on here
0 REPLIES 0
Technology Administrators
