I'm trying to make placement of standard components easier for a company
I've added 3 iMates:
- centerline mate (centerline at end of conveyorbelt)
- midplane mate
- Groundplane Angle
Centerline fixes position, leaving axial and radial movement
Midplane blocks axial movement
Then angle blocks radial movement
When I do it without adding the 3 iMates to an iComposite:
![Cadkundenl_1-1720781092982.png Cadkundenl_1-1720781092982.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1386017i1B45F29F309AFA4C/image-size/medium?v=v2&px=400)
When I add the 3 iMates to an iComposite and place the components in an assembly using iMates:
![Cadkundenl_2-1720781117318.png Cadkundenl_2-1720781117318.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1386018i28A8139376868F5C/image-size/medium?v=v2&px=400)
Looking at the iMate properties in the assembly:
![Cadkundenl_3-1720781138665.png Cadkundenl_3-1720781138665.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1386020i70F6040F5B1D8CF4/image-size/medium?v=v2&px=400)
Looking at the imate properties inside the parts:
![Cadkundenl_4-1720781229548.png Cadkundenl_4-1720781229548.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1386021i711EC68B776CD76D/image-size/medium?v=v2&px=400)
When using iComposite, it is undirected, and if I press "G" for free move, I can rotate the part and then it snaps correctly: Confirming solution = undirected.
There is no option in iMate to choose directed or undirected, and when I look in the iMate, it says directed.
Plz autodesk tell me what is going on here
