Dear community,
I added some fasteners to a custom content center library but the items in the selection lists are in a random order.
I want the nominal length to be ascending... How can I achieve this?
Solved by Jef_E. Go to Solution.
This order is not random I guess? It is the order of the dimensions in the table that belongs to the Content Center Family?
Do you mean that the order of the key columns in the family table (left to right) represents the the sorting order?
In my case:
- first sort all items ascending on then nominal length
- then alphabetically on material
- finally on thread description
No I mean that in the snippit you attached: in the column nominal length the length 12 is not in the correct position.
It show like this
But you want it to show as
So my best guess is to move the 12 nominal length row below the 10 and then it will be fixed. You should always insert rows at the correct position.
May I ask how do you check if an fastener is in stock or not? 😄
Maybe, you can try open the excel and sort it by selecting the table and right click sort ...
