Place drawing view using iLogic
S7RM7RPR
Message 1 of 15
S7RM7RPR
Ok so I've been trying to take the info from this post and to modify it to suit my purposes. Being that I only want one drawing view. But I'm getting an error on the last line and I'm not sure what I'm going wrong.. Also, not sheet metal, not sure what that changes...
http://forums.autodesk.com/t5/inventor-customization/ilogic-how-to-place-flat-pattern-on-the-drawing...
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Dim oPartDoc As Document
Dim oSheet As sheet
Dim oDoc1 As String = ThisDoc.FileName(False)
SpiderID = Right(oDoc1,(Len(oDoc1)-1)) ' Templates are named differently for different parts. In this case value is "1"
ViewScale = 1
oSheet = ThisDoc.Document.Sheets.Item(1)
Dim oBaseViewOptions As NameValueMap
oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
oBaseViewOptions.Add("SPIDER" & SpiderID & ".ipt", False)
oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(3, 10) ' front view
oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, ViewScale, kFrontViewOrientation, kHiddenLineDrawingViewStyle, "View1")
Replies (14)
Message 2 of 15
MechMachineMan
You call oPartDoc in the last line, but never defined what it is. (You have oDoc1 instead)
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 15
S7RM7RPR
Does that mean you know how to do it because that answer is a little vague on how to fix it....
Message 4 of 15
MechMachineMan
Dim oSheet As sheet
ViewScale = 1
oSheet.DrawingViews.AddBaseView(oDoc1, oPoint1, ViewScale, kFrontViewOrientation, kHiddenLineDrawingViewStyle, "View1")
'You called oPartDoc here, but didnt define it anywhere. use oDoc1 instead, or a different DEFINED variable 'oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, ViewScale, kFrontViewOrientation, kHiddenLineDrawingViewStyle, "View1")
This synatx may be wrong, so you may need to go into the Programming Help through inventor and find what the appropriate syntax is for:
.AddBaseView
This will likely be the wrong format for your first parameter in .AddBaseView. I am not sure as I am not going to do all of the work for you.
Justin K
Message 5 of 15
S7RM7RPR
The syntax is correct as far as I can tell. I've simplified the code as best as I can and assuming that I've done it correctly, it's still not working. Also, as a side note I am not a programmer and this particular chunk is an entirely new function to me. I'm learning on the fly with all this so I really appreciate any help you can give me.
Based on the error below I'm doing something wrong with "oPartDoc" but I don't understand what
"Unable to cast object of type 'System.String' to type 'Inventor.Document'."
SpiderID = Right(ThisDoc.FileName(False),(Len(ThisDoc.FileName(False))-1))
oPartDoc = ("path\SPIDER1.ipt")
oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(9, 10) ' front view
oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, 0.5, kFrontViewOrientation, kHiddenLineDrawingViewStyle, "View1")
Message 6 of 15
MechMachineMan
That right there says your syntax is wrong. In plain english, it's saying "You are trying to make a string go where a document belongs.
Looking at the rest of the code, (and if you actually checked the syntax through the programming help which is an ESSENTIAL tool for doing anything more than the absolute basics of iLogic), you would see:
DrawingViews.AddBaseView Method
Parent Object: DrawingViews
Description
Method that creates a new base . The newly created DrawingView is returned.
Syntax
DrawingViews.AddBaseView( Model As Document, Position As Point2d, Scale As Double, ViewOrientation As ViewOrientationTypeEnum, ViewStyle As DrawingViewStyleEnum, [ModelViewName] As String, [ArbitraryCamera] As Variant, [AdditionalOptions] As Variant ) As DrawingView
 Which says that the First Parameter for .AddBaseView is a document.
oPartDoc as you have it is a string (you can tell because it has quotation marks in it).
You will need to grab the Model Document itself and then pass it to add base view.
Ie;
'This ensures that what you give oPartDoc is a Document Type.
oPartDoc = ThisApplication.ActiveDocument
'This will return the active document, which might not necessarily be what you want but it is a good example
Justin K
Message 7 of 15
S7RM7RPR
I'm confused, isn't oPartDoc the part that I want a view of? The way I have it set up is I'm trying to get the views of parts in an assembly. I need to set up 72 different templates which is why I'm trying to figure out this code. If I don't have to manually insert each view it's going to save me a lot of work
Also just to be clear, I'm using this code on the idw right?
Message 8 of 15
MechMachineMan
This also looks terribly wrong to me based upon the syntax in the Programming help.
If you are just trying to rename the view, you might want to look into simpler methods under the .DrawingView object.
Justin K
Message 9 of 15
MechMachineMan
Yes, oPartDoc is supposed to be the part document.
You could get this functionality out of either an .idw or a .iam. It just depends on how the rest of your code is set up.
Justin K
Message 10 of 15
S7RM7RPR
*sigh* I needed the code in the individual parts. I'll go smack my head against the wall now.
New problem with that however, is that it creates a new idw instead of editing the one that I want to add the view to...
Message 11 of 15
MechMachineMan
If nothing else, you may want to look into using a Sheet Format with a view in it.
That way, you simply have to select to use the sheet format, and then if it contained a view, it will ask you for a file to put in it's place.
It will be useful for if it is all in the same .idw, but not so much if it isn't.
Justin K
Message 12 of 15
S7RM7RPR
I'm sorry I'm getting rather lost here. I put the code into my parts and it works there but it creates a new idw.
What I am trying to do is this.
I have a large number of parts.
Each part needs it's own drawing.
I can't have it set up as multiple sheets because the parts used will change all the time.
I have idw files set up for the different parts, but now I need to put a view of each part onto it's idw and save that idw. The actual format and size of the view isn't important because I still need to go through and do more editing.
Does that make sense or am I just barking up the wrong tree and should just do it manually
Message 13 of 15
MechMachineMan
I guess a lot of it depends how you were going to match your parts to your
.idws if your idws are already created.
I have made myself a code that goes through all of the parts in an
assembly, makes an idw, puts a view in it, and saves it using a formulaic
name. So it is possible if you know what you are doing.
Justin K
Message 14 of 15
S7RM7RPR
Seeing as I am totally making this up as I go it seems like I'm better off just doing it manually then. Apparently my project is getting too complicated for simple solutions >.<
Thank you very much for your help
Message 15 of 15
MechMachineMan
You could also try messing around with something like this untested code to use in your main assembly:
Dim oDoc As Document = ThisApplication.ActiveDocument
For j=0 to oDoc.ReferencedDocuments.Count
         oDrawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject,"C:\Template File.idw", False)
         oDwgName = "C:\String here.idw"
         oModel = oDoc.ReferencedDocuments.Item(j)
         oFormat = oDrawDoc.SheetFormats.Item(3) ' Change this to whatever u want to use
         oDrawDoc.Activate
         oSheet = oDrawDoc.Sheets.AddUsingSheetFormat(oFormat, oModel,"xxx",,,)
         oDrawingDoc.Sheets.Item(1).Delete
         oDrawDoc.SaveAs(oDwgName, True)
         oDrawDoc.Close
Next
Justin K
