Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Part Volume
2 REPLIES 2
366 Views, 2 Replies
Part Volume
I need a little help taking care of a client who needs to be able to add the
part volume to his drawing information (title block). He makes plastic parts
and would like this information to help with costing information. He would
like for the information to be parametrically linked to the model so that
the updates are automatic as his design matures.
Any help would be appreciated
Carl Smith
CADvantage, Inc
888-891-1700
2 REPLIES 2
Carl,
I'm looking at this small problem to and I think
5.3 will be the easy answer, because it's possible to create macro that is
executed automatically when the part is saved (AutoSave macro)
In release 5 you need to make a add-in to get the
same functionality
This basic VBA example should run on both versions,
it only works when the part is opened as a single document (watch
out for word-wraps!!)
Public Sub AutoSave()
    Dim oCompDef As
ComponentDefinition
    Dim TotalMass, TotalVolume As
Double
    Dim oProp As
Property
    Dim oPropSet As
PropertySet
    On Error Resume Next
Set oCompDef =
ThisApplication.ActiveDocument.ComponentDefinition
    oCompDef.MassProperties.Accuracy =
k_High
    TotalMass =
oCompDef.MassProperties.Mass
    TotalVolume =
oCompDef.MassProperties.Volume
    'Add
a custom property "TotalMass" with the Part Mass
    Set
oPropSet =
ThisApplication.ActiveDocument.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
oPropSet.Item("Totalmass").Delete
    'The check of unit type
must be enhanced to all the possibilities
    If
ThisApplication.ActiveDocument.UnitsOfMeasure.MassUnits = kKilogramMassUnits
Then
        Call
oPropSet.Add(Format((TotalMass / 1000), "#0.####") & " kg",
"Totalmass")
Else
        Call
oPropSet.Add(Format((TotalMass / 453.59237), "#0.####") & " lb",
"Totalmass")
    'Add a custom property "TotalVolume" with the Part
Volume
    Set oPropSet =
oPropSet.Item("TotalVolume").Delete
    'The check of unit
type must be enhanced to all the possibilities
    If
ThisApplication.ActiveDocument.UnitsOfMeasure.LengthUnits =
kMillimeterLengthUnits Then
        Call
oPropSet.Add(Format(TotalVolume, "#0.0####") & " mm^3",
"TotalVolume")
Else
        Call
oPropSet.Add(Format(TotalVolume, "#0.0####") & " in^3",
"TotalVolume")
    'Uses
i.e. the Cost Center value to the Part Mass as a workaround because the a model
custom property can't be transferred to the drawing
    Set
oProp =
ThisApplication.ActiveDocument.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").ItemByPropId(9)
'The check of unit type must be enhanced to all the
possibilities
    If
Then
        oProp.Value =
(Format((TotalMass / 1000), "#0.####") & " kg")
Else
        oProp.Value =
(Format((TotalMass / 453.59237), "#0.####") & "lb")
    'Uses i.e. the Authority
value to the Part Volume as a workaround because the a model custom property
    Set oProp =
ThisApplication.ActiveDocument.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").ItemByPropId(43)
possibilities
    If
oProp.Value = (Format(TotalVolume, "#0.0####") & "
mm^3")
    Else
in^3")
End Sub
> I need a little
> part volume
> and
that
> Carl Smith
> CADvantage,
Inc
> 888-891-1700
Thanks Patrick
Carl,
same functionality
versions, it only works when the part is opened as a single
document (watch out for word-wraps!!)
    Dim oCompDef As
ComponentDefinition
Double
    Dim oProp As
Property
    Dim oPropSet As
PropertySet
    On Error Resume
Next
    Set oCompDef =
k_High
    TotalMass =
    TotalVolume =
'Add a custom property "TotalMass" with the Part Mass
Set oPropSet =
    'The check of unit
    If
Then
        Call
"Totalmass")
Else
        Call
"Totalmass")
Volume
    Set oPropSet =
    'The check of unit
    If
        Call
"TotalVolume")
Else
        Call
"TotalVolume")
    'Uses
model custom property can't be transferred to the
drawing
    Set oProp =
possibilities
    If
Then
        oProp.Value =
Else
        oProp.Value =
    Set oProp =
possibilities
    If
mm^3")
Else
        oProp.Value =
(Format(TotalVolume, "#0.0####") & " in^3")
    End
If
End Sub
> I need a little
> part
parts
matures.
> Carl
Smith
> CADvantage, Inc
> 888-891-1700
Technology Administrators
