Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
override dimension value in drawing thru ilogic
2 REPLIES 2
dhaval3112
176 Views, 2 Replies
hello,
I want to override dimension value in drawing thru ilogic, with respect to drawing parameter
like... parameter size : 123 then dimension value should be 300
else 234 then 600........any idea how to do that.
regards,
Dhaval
Tags (1)
Labels (1)
2 REPLIES 2
d_eckel
in reply to: dhaval3112
Hi Dhaval,
I just tried a little bit and got this code working.
Dim oDoc As DrawingDocument = ThisDrawing.Document
MessageBox.Show(oDoc.Sheets.Item(1).DrawingDimensions.Item(1).ModelValue, "Title")
'oDoc.Sheets.Item(1).DrawingDimensions.Item(1).ModelValue '<- This is the real value
oDoc.Sheets.Item(1).DrawingDimensions.Item(1).ModelValueOverridden = True '<- set override
oDoc.Sheets.Item(1).DrawingDimensions.Item(1).OverrideModelValue = 15 '<- set value
The rest should be just some for each statements (e. g. sheets) and check if the value is equal to 123 or something else.
dhaval3112
in reply to: d_eckel
@d_eckel ,
thanks its work perfectly.
Technology Administrators
