hello,
I want to override dimension value in drawing thru ilogic, with respect to drawing parameter
like... parameter size : 123 then dimension value should be 300
else 234 then 600........any idea how to do that.
regards,
Dhaval
Solved by d_eckel. Go to Solution.
Hi Dhaval,
I just tried a little bit and got this code working.
Dim oDoc As DrawingDocument = ThisDrawing.Document MessageBox.Show(oDoc.Sheets.Item(1).DrawingDimensions.Item(1).ModelValue, "Title") 'oDoc.Sheets.Item(1).DrawingDimensions.Item(1).ModelValue '<- This is the real value oDoc.Sheets.Item(1).DrawingDimensions.Item(1).ModelValueOverridden = True '<- set override oDoc.Sheets.Item(1).DrawingDimensions.Item(1).OverrideModelValue = 15 '<- set value
The rest should be just some for each statements (e. g. sheets) and check if the value is equal to 123 or something else.
