Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
My ilogic code can't run it got the following error, I hope the experts can help me
14 REPLIES 14
Message 1 of 15
ngtatsang98
770 Views, 14 Replies
Code ilogic của mình không chạy được nó bị lỗi như sau, mong các chuyên gia giúp mình
Labels (1)
14 REPLIES 14
Message 2 of 15
ngtatsang98
in reply to: ngtatsang98
ilogic , automatically export drawings with errors
Message 3 of 15
A.Acheson
Hi @ngtatsang98
Can you show the more info tab of the error message box? The first tab only suggest there is an error but the second will give a little more information as to what the error is. Also have you narrowed down approximately where the rule is failing? If not place in a message box move it down each line untill you cannot see it being launched. This will help narrow down what to look at.
Regards
Alan
Message 4 of 15
ngtatsang98
in reply to: A.Acheson
More infor:
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Documents.Add(DocumentTypeEnum DocumentType, String TemplateFileName, Boolean CreateVisible)
at LmiRuleScript.CreateDrawing_PlaceViews(String PartNumber, Double DrawingViewScale, String ViewsToPlace, Boolean AssemblyDrawing, DrawingView& oBaseView, DrawingView& oView2, DrawingView& oView3, DrawingView& oView4)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Message 5 of 15
A.Acheson
Hi @ngtatsang98
The error suggest there is a missing string object. Does the template file path exist? There could be other string errors but that is a good one to check first. If it does exist I would suggest turn off all other actions and get that function to work first.
In Function CreateDrawing_PlaceViews Check this path.
"C:\Users\Public\Documents\Autodesk\Inventor 2017\Templates\standard.dwg"
Regards
Alan
Message 6 of 15
ngtatsang98
yes it worked partially then got the error again
Error in rule: Rule0, in document: Part5.ipt
More info:
at Inventor.DimensionStylesEnumerator.get_Item(Object Index)
at LmiRuleScript.CreateLinearDimension(DrawingDocument oDrawingDoc, DrawingView oDrawingView, DoubleForEquals DimensionLength, String DirectionOfDim, Double OffsetDistance, String DimensionLocation, Boolean ReferencedDim)
Message 7 of 15
A.Acheson
You have a string error in
String "DimensionLocation" but I am not sure why it is saying in part5.ipt.
Regards
Alan
Message 8 of 15
ngtatsang98
it still doesn't seem to work , part5 is the filename where i run this code .
This code is not written by me so I can't understand it, I hope you can fix it
Message 9 of 15
ngtatsang98
I use inventor 2018 version, this code is recommended for 2017 version
Message 10 of 15
A.Acheson
Hi @ngtatsang98
So if I remember this forum post this code was in is about 100 messages long so this code for sure has major functionality but it really is specific to that users workflow and so is very specific. Can you edit the first post and add the forum post link to where you found the code as it is always good practice to reference the original authors.
If your only starting out automating drawings I would suggest to start off small and just keep it simple.
I have modified the original rule to just do the basics. You can add and modify it later if you know what the next task you need is.
Option Explicit On
Sub Main()
	'Ask to Create Drawing
	Dim AskCreateDrawing As MsgBoxResult = MessageBox.Show("Would you like to Create Drawings for the Current Model?", "Drawing Automation",MessageBoxButtons.YesNo)
	'If the User Presses YES
	If AskCreateDrawing = vbYes Then
		'Set the View Scales
		Dim DrawingViewScale As Double = 1/10
		Dim oBaseView,oView2,oView3,oView4 As DrawingView
		Dim sAssyFileName As String = ThisDoc.FileName(False) 'without extension
		Dim oDrawDoc As DrawingDocument = CreateDrawing_PlaceViews (sAssyFileName, DrawingViewScale, "Right_Project", True)
		'Save As oDrawingDoc (Path and File Name)
		Dim sPath As String = ThisDoc.Path
		Dim sDrawFullFileName As String = sPath & "\" & sAssyFileName & ".dwg"
		oDrawDoc.SaveAs(sDrawFullFileName, False)
End Sub
Function CreateDrawing_PlaceViews (PartNumber As String, DrawingViewScale As Double, ViewsToPlace As String, AssemblyDrawing As Boolean)
	Dim oPartDoc As Document
	Dim oSheet As Sheet
	Dim oTG As TransientGeometry
	Dim oPoint1,oPoint2,oPoint3,oPoint4 As Point2d
	'If this is the Assembly View, then use this Document as reference and open Drawing Template
	'Otherwise use the given Part Number And invisibly open the part, Use the active drawing
	If AssemblyDrawing = True Then
		oPartDoc = ThisDoc.Document
		oDrawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\Users\Public\Documents\Autodesk\Inventor 2018\Templates\standard.dwg", True)
	Else If AssemblyDrawing = False
		Dim sPartDocPath As String = ThisDoc.Path & "\" & PartNumber & ".ipt"
		oPartDoc = ThisApplication.Documents.Open(sPartDocPath, False)
		oDrawDoc = ThisApplication.ActiveDocument
	oSheet = oDrawDoc.Sheets.Item(1)
	oTG = ThisApplication.TransientGeometry
	'Set points in order to get wanted View (ie. if 'Y' is the same and 'X' is greater or less, you will get a Side View)
	oPoint1 = oTG.CreatePoint2d(5, 5)
	oPoint2 = oTG.CreatePoint2d(5, 30)
	oPoint3 = oTG.CreatePoint2d(30, 5)
	oPoint4 = oTG.CreatePoint2d(30, 30)
	'Create the Base View
	oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, DrawingViewScale, kFrontViewOrientation, kHiddenLineDrawingViewStyle, "Default")
	oBaseView.ShowLabel = True
	'//////// Place the rest of the Projected Views According to the Parameter String Specified ////////////
	oView2 = oSheet.DrawingViews.AddProjectedView(oBaseView, oPoint3, kHiddenLineDrawingViewStyle, DrawingViewScale)
	oView2.ShowLabel = True
	oView3 = oSheet.DrawingViews.AddProjectedView(oBaseView, oPoint4, kHiddenLineDrawingViewStyle, DrawingViewScale)
	oView3.ShowLabel = True
	'Return the Drawing Document
	Return oDrawDoc
End Function
Regards
Alan
Message 11 of 15
ngtatsang98
Your code has some errors
Error on Line 58 : 'kFrontViewOrientation' is not declared. It may be inaccessible due to its protection level.
Error on Line 58 : 'kHiddenLineDrawingViewStyle' is not declared. It may be inaccessible due to its protection level.
Error on Line 63 : 'kHiddenLineDrawingViewStyle' is not declared. It may be inaccessible due to its protection level.
Error on Line 65 : 'kHiddenLineDrawingViewStyle' is not declared. It may be inaccessible due to its protection level.
and warnings
Warning on Line 12 : Unused local variable: 'oBaseView'.
Warning on Line 12 : Unused local variable: 'oView2'.
Warning on Line 12 : Unused local variable: 'oView3'.
Warning on Line 12 : Unused local variable: 'oView4'.
Message 12 of 15
ngtatsang98
The code I found has almost no instructions, but I'm sure it does the output of the drawing fill in dimensions automatically.
this is where i found it:
https://github.com/AlexFielder/iLogic/blob/master/Drawings/Drawing%20Automation%20Code.iLogicVb
Message 13 of 15
A.Acheson
Hi @ngtatsang98
Just comment off this line as I was using that to better declare variables.
'Option Explicit On
Regards
Alan
Message 14 of 15
ngtatsang98
I tried again it seems to go back to the original error
 More info
at Inventor.DrawingViews.AddBaseView(_Document Model, Point2d Position, Double Scale, ViewOrientationTypeEnum ViewOrientation, DrawingViewStyleEnum ViewStyle, String ModelViewName, Object ArbitraryCamera, Object AdditionalOptions)
at LmiRuleScript.CreateDrawing_PlaceViews(String PartNumber, Double DrawingViewScale, String ViewsToPlace, Boolean AssemblyDrawing)
Message 15 of 15
A.Acheson
Hi @ngtatsang98
Did you launch the rule from a drawing? If so the function would be supplying the drawing document to the view which of course would be wrong.
Here is a more simplified version of the same rule with some document checks. Also the document is supplied from one source set at the start of the rule and passed into the function as an argument.
Sub Main()
	Dim oDoc As Document = ThisDoc.Document
	If oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then MessageBox.Show("Not a Part/Assembly so Exiting!","Error" ) : Exit Sub
	If Not AskCreateDrawing = vbYes Then Exit Sub
	Dim oDrawDoc As DrawingDocument = CreateDrawing_PlaceViews (oDoc, DrawingViewScale)
End Sub
Function CreateDrawing_PlaceViews (oDoc As Document, DrawingViewScale As Double)
	Dim oDrawDoc As DrawingDocument = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\Users\Public\Documents\Autodesk\Inventor 2018\Templates\standard.dwg", True)
	Dim oSheet As Sheet = oDrawDoc.Sheets.Item(1)
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	oBaseView = oSheet.DrawingViews.AddBaseView(oDoc, oPoint1, DrawingViewScale, kFrontViewOrientation, kHiddenLineDrawingViewStyle, "Default")
	Return oDrawDoc
End Function
Regards
Alan
Technology Administrators
