How to exclude folders with spaces in the name in contains()
Thomas1365
Message 1 of 8
Thomas1365
I am trying to create an iLogic rule which will sift through assemblies and extract information from the iProperties and export it to an excel spreadsheet.I have leveraged heavily off of a previous forum post which wants to do something similar: https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/iproperties-export-to-excel/td-p/921...
I have a number of folders that I do not want to search through in the directory, such as OldVersions in the forum post above. The rule works great for excluding folders without and spaces in the name, but it won't run if I try to search for folders with a space.
I made a test folder where I have some parts and three folders: "OldVersions", "TestFolder" and "Test Folder" each with parts in them to try debug it.  Using the following lines of code will ignore the parts in OldVersions and TestFolder, and find the part in Test Folder:
	For Each File As IO.FileInfo In Folder.GetFiles("*.ipt",IO.SearchOption.AllDirectories)
	    If File.FullName.Contains("OldVersions" ) = False Then
			If File.FullName.Contains("TestFolder") = False Then
				FileList.Add(File.FullName)
	Next
 I want to exclude all 3 folders, and tried the following lines of code:
				If File.FullName.Contains("Test Folder") = False Then
	Next
 However this fails to run, I think the rule gets to the line with "Test Folder" then cancels. How do I define folder names with the spaces?
Thanks in advance
Replies (7)
Message 2 of 8
FINET_Laurent
Hi @Thomas1365,
Is there a specific reason why you are using .contains intead of equal ? If you are looking for specific folder name, I would do it like this (and also cleaning the code with guard clauses) :
	If File.FullName = "OldVersions" Then Continue For
	If File.FullName = "TestFolder" Then Continue For
	If File.FullName = "Test Folder" Then Continue For
Next
Does this suits your needs  ?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 8
Thomas1365
Thanks for the response @FINET_Laurent,
I think that's a better approach, however I do want to exclude those files so I tried:
	If File.FullName Is Not "OldVersions" Then Continue For
	If File.FullName Is Not "TestFolder" Then Continue For
	If File.FullName Is Not "Test Folder" Then Continue For
Next
 However it didn't work. Is it a syntax issue on my end?
Message 4 of 8
FINET_Laurent
Hi @Thomas1365,
I think it is indeed an issue on your side. You should replace the "Is Not" statement with a simple " = " as I did, and I suppose it will do the trick. To understand this better, here is some lecture :
Guard Clause | DevIQ
Continue Statement - Visual Basic | Microsoft Learn
Kind regards,
FINET L.
Message 5 of 8
Curtis_Waguespack
Hi @Thomas1365 and @FINET_Laurent
I think contains is required here, because File.Fullname is returning the file path.
You could use something like this:
Dim Folder As New IO.DirectoryInfo("C:\Temp")
Dim FileList As New List(Of String)
For Each File As IO.FileInfo In Folder.GetFiles("*.ipt", IO.SearchOption.AllDirectories)
	If File.FullName.contains("OldVersions") Then Continue For
	If File.FullName.contains("TestFolder") Then Continue For
	If File.FullName.contains("Test Folder") Then Continue For
Next
or maybe something like this
Dim RootFolder As New IO.DirectoryInfo("C:\Temp")
For Each oFolder As IO.DirectoryInfo In RootFolder.GetDirectories("*", IO.SearchOption.AllDirectories)
	If oFolder.Name = "OldVersions" Then Continue For
	If oFolder.Name = "TestFolder" Then Continue For
	If oFolder.Name = "Test Folder" Then Continue For
	For Each File As IO.FileInfo In oFolder.GetFiles("*.ipt", IO.SearchOption.AllDirectories)
	Next
Next
Or even something like this:
Dim ExcludeList = New String() {"OldVersions", "TestFolder", "Test Folder" }
	If ExcludeList.Contains( oFolder.Name) Then Continue For
	Next
Next
I hope this helps.
Curtis
Message 6 of 8
Thomas1365
Thanks for your help @Curtis_Waguespack and @FINET_Laurent .
I liked the 3rd rendition the most as it's the cleanest and I can easily add more filenames to exclude (the real application has many more different file names and sub folders). This seems closer to working how I want, however it doesn't return the parts within the root folder.
I tried to solve this by taking the RootFolder up a level, however it then returns everything within the folder because (I believe) it's only checking for the "ExcludeList" the initial time and then adds it to the list. I think I need to add another layer to the For loop to check again within each folder.
I think it might help if I explain a bit better my testing folder arrangement:
  •  S:\Testing\Macro Testing:
    • S:\Testing\Macro Testing\Testing Folder
      • S:\Testing\Macro Testing\Testing Folder\OldVersions
        • I DONT WANT THIS.ipt
      • S:\Testing\Macro Testing\Testing Folder\Test Folder
      • S:\Testing\Macro Testing\Testing Folder\TestFolder
      • Cube 2.ipt
      • Cube 1.ipt
So I know if I see the "I DONT WANT THIS" part it's looked in the wrong folder (I also have it returning the file directory to double check).
If I run the RootFolder as "S:\Testing\Macro Testing\Testing Folder" I will get no results in my exported excel, I believe this is because the script doesn't say to check in the RootFolder itself for .ipt files. So I changed the RootFolder to be a level up as: "S:\Testing\Macro Testing". This then returns every part including the "I DONT WANT THIS" as I mentioned.
I have tried to add another check for the ExcludeList after finding applicable folders:
Dim RootFolder As New IO.DirectoryInfo("S:\Testing\Macro Testing")
Dim ExcludeList = New String() {"OldVersions", "TestFolder", "Test Folder"}
	If ExcludeList.Contains(oFolder.Name) Then Continue For
		For Each oSubFolder As IO.DirectoryInfo In oFolder.GetDirectories("*", IO.SearchOption.AllDirectories)
			If ExcludeList.Contains(oSubFolder.Name) Then Continue For
				For Each File As IO.FileInfo In oSubFolder.GetFiles("*.ipt", IO.SearchOption.AllDirectories)
				Next
			Next
		Next
Next
However this returns nothing when running the script. I think I need to better define to first look for parts in the first level of the folders, and then look at the folders, then ignore any from the ExcludeList.
Thanks so much for your help. This is my first time trying to make anything in iLogic  and I also don't have any programming background, so I apologise if I'm missing obvious things.
Message 7 of 8
Curtis_Waguespack
Hi @Thomas1365
Try this version. It first gets a list of folders, then looks through those folders for files
I hope this helps.
Curtis
Dim FolderList As New List(Of IO.DirectoryInfo)
'add root folder
FolderList.Add(RootFolder)
'get sub folders
	FolderList.Add(oFolder)
Next
For Each oFolder In FolderList
	For Each File As IO.FileInfo In oFolder.GetFiles("*.ipt", IO.SearchOption.TopDirectoryOnly)
	Next
Next
Message 8 of 8
Thomas1365
Hi @Curtis_Waguespack,
That works! Fantastic. Thank you very much.
I have added another layer to the smarts of the script to eliminate parts from the list I do not want to open. I've achieved this by adding another string for "ExcludeListParts", below removed Cube 2 from being added to the file list:
Dim ExcludeListParts = New String() {"Cube 2.ipt"}
'add root folder
'get sub folders
Next
		If ExcludeListParts.Contains(File.Name) Then Continue For
	Next
Next
Is there a way to eliminate a file with a certain key word from being added to the list?
