I have the following code for obtaining the cylindrical faces in the open geometry. I want to modify the radius of the cylinder. How should I proceed with this?
public static void HoleList(Inventor.Application mApplication)
PartDocument doc = (PartDocument)mApplication.ActiveDocument;
PartComponentDefinition PartCompDef = doc.ComponentDefinition;
SurfaceBody body = PartCompDef.SurfaceBodies[1];
int holeCount = 0;
int count = body.Faces.Count;
foreach (Face face in body.Faces)
if (face.SurfaceType == SurfaceTypeEnum.kCylinderSurface)
holeCount++;
Cylinder cylinder = (Cylinder)face.Geometry;
double ddepth = 0.0;
if (cylinder.AxisVector.Z == 1 || cylinder.AxisVector.Z == -1)
ddepth = System.Math.Abs(System.Math.Abs(face.Vertices[1].Point.Z) - System.Math.Abs(face.Vertices[2].Point.Z)) * 10;
else if (cylinder.AxisVector.Y == 1)
ddepth = System.Math.Abs(System.Math.Abs(face.Vertices[1].Point.Y) - System.Math.Abs(face.Vertices[2].Point.Y)) * 10;
else if (cylinder.AxisVector.X == 1)
ddepth = System.Math.Abs(System.Math.Abs(face.Vertices[1].Point.X) - System.Math.Abs(face.Vertices[2].Point.X)) * 10;
double diameter = 2 * cylinder.Radius;
Console.WriteLine("Diameter: " + cylinder.Radius * 2 * 10 + " mm" + "\t" + "Depth: " + ddepth + " mm");
foreach(Edge edge in face.Edges)
Console.WriteLine(edge.StartVertex.Point.X + " " + edge.StartVertex.Point.Y + " " + edge.StartVertex.Point.Z);
Console.WriteLine(edge.StopVertex.Point.X + " " + edge.StopVertex.Point.Y + " " + edge.StopVertex.Point.Z);
Any help will be greatly appreciated. Thank you.
You can't modify surface body directly in this way, but you can use ThickenFeature for this.
Hi. Can you provide a simple code example for this? I am new to this and I am unable to get ThickenFeature to work with the code.
This is simple iLogic sample how to create ThicknessFeature from all cylindrical faces
Sub Main()
Dim part As PartDocument = ThisDoc.Document
Dim partDef As PartComponentDefinition = part.ComponentDefinition
'Iterate all faces in first surface body
For Each face As Face In partDef.SurfaceBodies(1).Faces
'Check if face is cylindrical face
Dim cylinder As Cylinder = TryCast(face.Geometry, Cylinder)
If cylinder Is Nothing Then Continue For
'Get radius for future use. Not used yet
Dim radius As Double = cylinder.Radius
'Build face collection for each face
Dim faceCollection As FaceCollection = ThisApplication.TransientObjects.CreateFaceCollection()
faceCollection.Add(face)
'Set offset/thickness distance. It can depend on current radius
Dim distance As Double = 0.1 ' 1 mm
'Create thickness feature
Dim thicknessFeature = partDef.Features.ThickenFeatures.Add(
faceCollection,
distance,
PartFeatureExtentDirectionEnum.kPositiveExtentDirection,
PartFeatureOperationEnum.kJoinOperation,
False)
Next
End Sub
