I have created some DimensionConstraint objects with the driven set to true. the dimensions are not showing up in the refence parameters collection both in the Inventor Parameters UI and watch window. I need these dimensions to show up as reference parameters. Do I have to add them to the reference table manually, am I missing something, or did I discover a bug?
Dim sdcVert As DimensionConstraint = (ClearanceModelProfileSketch.DimensionConstraints.AddTwoPointDistance(spOrigin, spProfile(i), DimensionOrientationEnum.kHorizontalDim, tg.CreatePoint2d(spDeckRight.Geometry.X / 2, spDeckRight.Geometry.Y - ((1 + i) * dDimensionOffset)), True)) With sdcVert.Parameter .Name = "ATR" & (i + 1) .Visible = True .Precision = Inventor.LinearPrecisionEnum.kSixteenthsFractionalLinearPrecision .Units = Inventor.UnitsTypeEnum.kFootLengthUnits .ExposedAsProperty = True With .CustomPropertyFormat .PropertyType = CustomPropertyTypeEnum.kTextPropertyType .Units = Inventor.UnitsTypeEnum.kFootLengthUnits .Precision = CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision '.ShowUnitsString = True End With End With
The following check code returns 0 after the sketch creates 6 very visible driven dimensions.
MsgBox(ClearanceModel.ComponentDefinition.Parameters.ReferenceParameters.Count)
After checking the open document, there are visible dimensions, they all have the appropriate names, and are all marked as driven, but the UI does not show them, not even a reference parameters section on the table. Please help me figure this out.
The created driven dimension's parameter (reference) is not visible to iLogic either. It is only visible to iProperties (custom). This is causing me a problem, because I can't ask for the iProperty its value if it is not numeric, because the parameter exported it as formated text what I get back in "31 in" instead of 31. As such I can not perform math on the stored value within iLogic, I would have to write elaborate code to get the value from the component reference, its cg and translate it to current space.
I don’t see any problem in your code snippet.
I made the simple VBA test to play with the reference parameters in a planar sketch. It creates new planar sketch in the active part and adds one reference dimension. Then it changes some properties in the associated parameter. Here is the result:
Sub AddReferenceDimension() 'create new part document and run this vba code Dim oDoc As PartDocument Set oDoc = ThisApplication.ActiveDocument Dim oDef As PartComponentDefinition Set oDef = oDoc.ComponentDefinition Dim oTG As TransientGeometry Set oTG = ThisApplication.TransientGeometry 'create 2D sketch on the X-Y plane Dim oSketch As PlanarSketch Set oSketch = oDef.Sketches.Add(oDef.WorkPlanes.Item(3)) 'draw 2d geometry Dim oSkPnts As SketchPoints Set oSkPnts = oSketch.SketchPoints Call oSkPnts.Add(oTG.CreatePoint2d(0, 0), False) Call oSkPnts.Add(oTG.CreatePoint2d(1#, 0), False) Call oSkPnts.Add(oTG.CreatePoint2d(1#, 0.5), False) Call oSkPnts.Add(oTG.CreatePoint2d(2.2, 0.5), False) Call oSkPnts.Add(oTG.CreatePoint2d(0.5, 1.5), False) Call oSkPnts.Add(oTG.CreatePoint2d(0, 1#), False) Call oSkPnts.Add(oTG.CreatePoint2d(2.7, 1.5), False) Call oSkPnts.Add(oTG.CreatePoint2d(0.5, 1#), False) Dim oLines As SketchLines Set oLines = oSketch.SketchLines Dim oLine(1 To 6) As SketchLine Set oLine(1) = oLines.AddByTwoPoints(oSkPnts(1), oSkPnts(2)) Set oLine(2) = oLines.AddByTwoPoints(oSkPnts(2), oSkPnts(3)) Set oLine(3) = oLines.AddByTwoPoints(oSkPnts(3), oSkPnts(4)) Set oLine(4) = oLines.AddByTwoPoints(oSkPnts(4), oSkPnts(7)) Set oLine(5) = oLines.AddByTwoPoints(oSkPnts(7), oSkPnts(5)) Set oLine(6) = oLines.AddByTwoPoints(oSkPnts(6), oSkPnts(1)) Dim oArc As SketchArc Dim oArcs As SketchArcs Set oArcs = oSketch.SketchArcs Set oArc = oArcs.AddByCenterStartEndPoint(oSkPnts(8), oSkPnts(5), oSkPnts(6)) 'add driven dimension Dim oDims As DimensionConstraints Set oDims = oSketch.DimensionConstraints Dim oPoint As Point2d Set oPoint = oTG.CreatePoint2d( _ (oLine(1).StartSketchPoint.Geometry.x + oLine(1).EndSketchPoint.Geometry.x) / 2, _ oLine(1).StartSketchPoint.Geometry.y - 1) Dim oDim As TwoPointDistanceDimConstraint Set oDim = oDims.AddTwoPointDistance( _ oLine(1).StartSketchPoint, _ oLine(1).EndSketchPoint, _ DimensionOrientationEnum.kHorizontalDim, _ oPoint, _ True) 'parameter properties With oDim.Parameter .name = "ATR" & (77) .Visible = True .Precision = Inventor.LinearPrecisionEnum.kSixteenthsFractionalLinearPrecision .units = Inventor.UnitsTypeEnum.kFootLengthUnits .ExposedAsProperty = True With .CustomPropertyFormat .PropertyType = CustomPropertyTypeEnum.kTextPropertyType .units = Inventor.UnitsTypeEnum.kFootLengthUnits .Precision = CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision End With End With End Sub
If you still have a problem please upload the model and the minimal buildable code that could help to reproduce the problem on our side.
thanks
Strange... The only fundamental difference I have is my sketch in an assembly model sketch, but that shouldn't really matter.
I am attempting two auto senarios that both have the same problem, dimension is created, but reference is not.
I can send you the full code, and it will run to that section. The files are created by the code, and the only thing that is supplied is the template, and a psuedo railcar part file.
I also see strange behavior when create dimensions in the assembly context.
Let me some time to investigate it.
Hi Jamie,
It looks like you've uncovered some problems with the Sketch portion of the Assembly API. My colleague from engineer team confirmed it. Unfortunately we do not see any workaround at the moment. Sorry for that.
We have logged Change Request number TFS 121060 “Missing parameters when create dimensions in 2D sketch in assembly document” with our development team as this issue requires a modification to our software. Please make a note of this number for future reference. You are welcome to request an update on the status of this issue, or to provide us with additional information.
Thank you very much for this case and discussion!
FYI I am getting this same problem whenthe dimension created is normal, not reference - aka driven. Its becomming a real buzz kill because accessing Inventor's parameters in this state, because when the sket ch containing these dimensions is deleted it causes the program to crash (fatally).
If you delete the dimension, or sketch containing these autocreated dimensions that have incorrect parameter data, then access the parameters window, Inventor will crash. If you search the parameters using code, Inventor will not find them, and crash. If you save the file with the sketch deleted, then close it, then open it, then open the parameters window Inventor does not crash, it shows parameters (the ones that have formulas attempting to use the missing parameters) as unreferenced parameters, and allows you to delete the user parameters so that I can recreate the whole lot of them.
Well something changed between Inventor 2019 and 2020 (currently using version 2020.0.1), this problem as resurfaced. Inventor is unstable after deleting assembly sketch dimensions that were created by code and deleted by hand. A detailed process list is below:
1. Code creates dimensional constraints in an assembly sketch, and modifies parameter export features.
2. Code creates custom parameters that use the dimensional parameters in their expressions (for rounding tricks).
3. User saves file and forgets all about this having happily completed their task.
4. User revisits same file many moons later, and wants to modify by hand the assembly sketch. During this time, they delete one or more of the dimensions being used in step 1 above.
5. User attempts to 'rebuild all' or runs same code command to 'update2', Inventor reads an incomplete parameter's table and crashes.
5a. User runs custom code to delete custom parameters with expressions that used orphaned dimensional parameters.
5b. User manually deletes custom parameters with expressions that used orphaned dimensional parameters.
5c. User or code run an update command (or rebuild all command), Inventor crashes.
Alternate step 5: User saves and closes file, or code saves and closes file. Then reopens it, Inventor reads the table data and populates in-memory data from the cleaned table, and does not crash upon update.
I have sent in several crash updates on this. Currently my Autodesk account can not access its 'View Support Cases' page as it once again redirects back to the home page.
Current version of Code that attempts to clean custom parameters before recreating them:
Public Sub ATRWideRound() Try GetInventorApplication() If invApp IsNot Nothing Then If invApp.ActiveDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Dim invdoc As Inventor.Document = invApp.ActiveDocument Dim trans As Transaction = invApp.TransactionManager.StartTransaction(invdoc, "ATRWide") ATRWideRoundReset(invdoc, trans) trans.End() End If End If Catch ex As Exception Dim eh As New ErrorHandler(ex) eh.HandleIt() End Try End Sub Public Function RemoveParameterAndIProperty(param As Parameter, dcs As List(Of DimensionConstraint), invDoc As Inventor.Document) As Boolean Dim booSuccess As Boolean = False Try Dim booFound As Boolean = False Dim strName As String = String.Empty If param.HealthStatus <> HealthStatusEnum.kDeletedHealth Then For Each dc As DimensionConstraint In dcs If dc.Parameter.Name = param.Name Then dc.Parameter.ExposedAsProperty = False Dim iProp As [Property] = FindiProperty(Tools.UserDefinedPropertySetID, dc.Parameter.Name, invDoc) If iProp IsNot Nothing Then iProp.Delete() ' ExportParameterAsFeetInches(dc.Parameter) booFound = True Exit For End If Next strName = param.Name param.Delete() Else 'don't remove - its has already been deleted by Inventor during the processing of our current code thread, such as when a user parameter that kept this one around as a formula value was deleted first. End If 'still check for iproperties that need to be removed after parameter was deleted. If booFound = False AndAlso String.IsNullOrWhiteSpace(strName) = False Then Dim iProp As [Property] = FindiProperty(Tools.UserDefinedPropertySetID, strName, invDoc) If iProp IsNot Nothing Then iProp.Delete() End If booSuccess = True Catch ex As Exception 'Dim strname As String = String.Empty 'Try ' If param IsNot Nothing Then ' If param.Name IsNot Nothing Then ' strname = param.Name ' End If ' End If ' 'MsgBox("Can not delete parameter and iProperty: " & strname & vbCrLf & ex.InnerException.ToString) 'Catch ex2 As Exception ' 'MsgBox("Can not delete parameter and iProperty, Inventor has a catastrophic error on this parameter. You will need to reload the file to clean.") 'End Try End Try Return booSuccess End Function Public Sub ATRWideRoundReset(ByRef docAsm As Inventor.AssemblyDocument, Optional ByRef trans As Transaction = Nothing) 'find "Clearance Profile" sketch Dim skClearanceProfile As PlanarSketch = Nothing For Each psk As PlanarSketch In docAsm.ComponentDefinition.Sketches If psk.Name = "Clearance Profile" Then skClearanceProfile = psk Exit For End If Next Dim dcATRs As New List(Of DimensionConstraint) Dim dcWides As New List(Of DimensionConstraint) Dim dcAllATRs As New List(Of DimensionConstraint) Dim dcAllWides As New List(Of DimensionConstraint) If skClearanceProfile IsNot Nothing Then For Each dc As Inventor.DimensionConstraint In skClearanceProfile.DimensionConstraints If dc.Parameter.Name.Contains("ATR") Then dcAllATRs.Add(dc) If Not dc.Parameter.Name = "ATRD" Then dcATRs.Add(dc) ElseIf dc.Parameter.Name.Contains("WIDE") Then dcAllWides.Add(dc) If Not dc.Parameter.Name = "WIDED" Then dcWides.Add(dc) End If Next Else MsgBox("Can not find sketch named 'Clearance Profile'") End If 'look for existing atr-wide rounded parameters'clear them out Dim booReLoadFile As Boolean = False Dim exATRs As List(Of Parameter) = GetParameterValues(docAsm, "ATR", True) If exATRs.Count > 0 Then Dim exATRRs As New List(Of Parameter) For Each param As Parameter In exATRs If param.Name.Substring(param.Name.Length - 1, 1) = "R" Then exATRRs.Add(param) Next For Each param As Parameter In exATRRs exATRs.Remove(param) Next For Each param As Parameter In exATRRs If RemoveParameterAndIProperty(param, dcAllATRs, docAsm) = False Then booReLoadFile = True End If Next For Each param As Parameter In exATRs If RemoveParameterAndIProperty(param, dcAllATRs, docAsm) = False Then booReLoadFile = True End If Next End If Dim exWides As List(Of Parameter) = GetParameterValues(docAsm, "WIDE", True) If exWides.Count > 0 Then Dim exWideRs As New List(Of Parameter) For Each param As Parameter In exWides If param.Name.Substring(param.Name.Length - 1, 1) = "R" Then exWideRs.Add(param) Next For Each param As Parameter In exWideRs exWides.Remove(param) Next For Each param As Parameter In exWideRs If RemoveParameterAndIProperty(param, dcAllWides, docAsm) = False Then booReLoadFile = True End If Next For Each param As Parameter In exWides If RemoveParameterAndIProperty(param, dcAllWides, docAsm) = False Then booReLoadFile = True End If Next End If If booReLoadFile Then MsgBox("File has errors and needs to be reloaded.") Dim strFileName As String = docAsm.FullFileName docAsm.Save() docAsm.Close() docAsm = OpenInventorFile(New IO.FileInfo(strFileName)) End If 'once old parameters are cleared out, create new ones based soley on the existence of the parameters found from the dimensions Dim dcATRWIDES As New List(Of DimensionConstraint) dcATRWIDES.AddRange(dcATRs) dcATRWIDES.AddRange(dcWides) For Each dc As DimensionConstraint In dcATRWIDES dc.Parameter.ExposedAsProperty = False Dim iProp As [Property] = FindiProperty(Tools.UserDefinedPropertySetID, dc.Parameter.Name, docAsm) If iProp IsNot Nothing Then iProp.Delete() ExportParameterAsFeetInches(dc.Parameter) Dim paraRound As Inventor.Parameter = Nothing Dim paramName As String = dc.Parameter.Name If paramName.ToUpper.Contains("ATR") Or paramName.ToUpper.Contains("WIDE") Then 'round(( ATR1 - 0.49 in ) / 1 in) * 1 in Dim sign As String = "+" Dim strExpression As String = "round(( " & paramName & " " & sign & " 0.49 in ) / 1 in) * 1 in" Dim dRemainderInches As Double = (CDbl(dc.Parameter.Value) * 2.54) Mod 1 If 0.09 < dRemainderInches AndAlso dRemainderInches < 1 / 32 Then strExpression = "round(( " & dc.Parameter.Name & " ) / 1 in) * 1 in" End If Dim strName As String = dc.Parameter.Name & "R" Try Dim uParams As UserParameters = docAsm.ComponentDefinition.Parameters.UserParameters paraRound = uParams.AddByExpression(strName, strExpression, Inventor.UnitsTypeEnum.kInchLengthUnits) Catch ex As Exception Dim eh As New ErrorHandler(ex) eh.HandleIt() End Try End If ExportParameterAsFeetInches(paraRound) Next If dcWides.Count > 0 Then Dim intRoundDown As Integer dcWides.Sort(Function(x, y) CInt(x.Parameter.Name.Replace("WIDE", "")).CompareTo(CInt(y.Parameter.Name.Replace("WIDE", "")))) For i As Integer = 0 To dcWides.Count - 1 dcWides(i).Parameter.ExposedAsProperty = False Dim iProp As [Property] = FindiProperty(Tools.UserDefinedPropertySetID, dcWides(i).Parameter.Name, docAsm) If iProp IsNot Nothing Then iProp.Delete() ExportParameterAsFeetInches(dcWides(i).Parameter) 'if next value is smaller than current value then this is the last integer we want to round down If i > 0 Then 'must always be 1 below the max count Dim dblValue As Double = dcWides(i - 1).Parameter.Value Dim dblValue2 As Double = dcWides(i).Parameter.Value If Math.Round(dblValue, 8) < Math.Round(dblValue2, 8) Then 'get integer value from name Dim strNumber As String = dcWides(i).Parameter.Name strNumber = strNumber.ToUpper.Replace("WIDE", "") intRoundDown = CInt(strNumber) 'Exit For End If End If Next For i As Integer = 1 To intRoundDown - 1 'get ATR rounded value by name = ATR1R Dim uParam As UserParameter = docAsm.ComponentDefinition.Parameters.UserParameters.Item("ATR" & i & "R") If uParam IsNot Nothing Then uParam.Expression = "round(( " & "ATR" & i & " - 0.49 in ) / 1 in) * 1 in" Dim dRemainderInches As Double = (CDbl(uParam.Value) * 2.54) Mod 1 If 0.09 < dRemainderInches AndAlso dRemainderInches < 1 / 32 Then uParam.Expression = "round(( " & "ATR" & i & " ) / 1 in) * 1 in" End If End If Next End If If docAsm.RequiresUpdate = True Then Dim strFileName As String = docAsm.FullFileName Dim transName As String = String.Empty Dim booRestartTransaction As Boolean = False If trans IsNot Nothing Then booRestartTransaction = True transName = trans.DisplayName trans.End() End If docAsm.Save() docAsm.Close() docAsm = OpenInventorFile(New IO.FileInfo(strFileName)) docAsm.Update2(True) If booRestartTransaction Then trans = invApp.TransactionManager.StartTransaction(docAsm, "transName") End If End If End Sub
Example of code used to create dimension:
'add vertical dimension constraint Dim sdcVert As DimensionConstraint = skProfile.DimensionConstraints.AddTwoPointDistance(slMirror.StartSketchPoint, OffsetProfile(i).StartProfilePoint.SketchPoint, DimensionOrientationEnum.kHorizontalDim, tg.CreatePoint2d(OffsetProfile(0).StartProfilePoint.SketchPoint.Geometry.X / 2, OffsetProfile(0).StartProfilePoint.SketchPoint.Geometry.Y + ((1 + i) * dDimensionOffset)), False) With sdcVert.Parameter .Name = OffsetProfile(i).StartProfilePoint.PointID '.DisplayFormat = ParameterDisplayFormatEnum.kArchitecturalDisplayFormat .Visible = True .Precision = Inventor.LinearPrecisionEnum.kSixteenthsFractionalLinearPrecision .ExposedAsProperty = True ' MsgBox(.InUse) With .CustomPropertyFormat .PropertyType = CustomPropertyTypeEnum.kTextPropertyType .Units = Inventor.UnitsTypeEnum.kFootLengthUnits .Precision = CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision '.ShowUnitsString = True End With End With sdcProfileVert.Add(sdcVert) 'add horizontal dimension constraints Dim intOppositeID As Integer = ((OffsetProfile.Count - 1) / 2) + i Dim sdcHorz As DimensionConstraint = skProfile.DimensionConstraints.AddTwoPointDistance(OffsetProfile(i).StartProfilePoint.SketchPoint, OffsetProfile(intOppositeID).StartProfilePoint.SketchPoint, DimensionOrientationEnum.kVerticalDim, tg.CreatePoint2d(lastPoint1.SketchPoint.Geometry.X + ((1 + i) * dDimensionOffset), 0), False) With sdcHorz.Parameter .Name = sdcVert.Parameter.Name.Replace("ATR", "WIDE") .Visible = True .Precision = Inventor.LinearPrecisionEnum.kSixteenthsFractionalLinearPrecision .ExposedAsProperty = True With .CustomPropertyFormat .PropertyType = CustomPropertyTypeEnum.kTextPropertyType .Units = Inventor.UnitsTypeEnum.kFootLengthUnits .Precision = CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision '.ShowUnitsString = True End With End With sdcProfileHorz.Add(sdcHorz)
I would really like to have a stable Inventor on this issue. I'm having to write a lot of workaround code (its not ideal to close and reopen the file in mid processing) just to keep the user working.
