Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
MATPROPS Publish tool add-in ignore existing files?
2 REPLIES 2
Clo-z-nuff_2
147 Views, 2 Replies
Is anyone using the Matprops Publish add-in to export Inventor flat patterns to dxf or dwg?  It appears this would work well for us but there are occasions where we will modify the exported dwg file and I don't want that file to be written over when the next mass dwg export takes place.  Is there a way to ignore existing files?
Thanks in advance.
2 REPLIES 2
w.pepping
in reply to: Clo-z-nuff_2
You need an option to keep the files from an earlier export?
As programmer of this tool I can help of course.
please describe your workflow.
regards,
Get control of your sheet metal files.
Download the app from matprop.com
Clo-z-nuff_2
in reply to: w.pepping
Hello @w.pepping, we re-use many components between designs and on occasion will have to make a manual change to the exported dwg file (we use dwg files to use on our plasma cut tables which use ProNest).  I don't want these manual changes overwritten.  So, if a file exists already in the assigned location, I don't want it to be overwritten.
I imagine a global selection button to allow these files to be over written or ignored.  Does that make sense?
Great tool, thanks for the response!
