Material Library
Material Library
sattju
Material Library
sattju
I am having issues with creating a material list. I am trying to add our plastic laminates and when I go to add a new material, the colors change. I am needing to add different colors to differentiate between the hundreds of plastic laminates that we use, but they are all trying to change to the same color for some reason and I can figure out why.
Am I doing something wrong here?
bradeneuropeArthur
Materials are based on Material Assets and Appearance Assets.
These need to be checked.
When you add a new Material, best practice is to also add a new Appearance asset to it.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
sattju
Got it! It's working now. Are they automatically added to my new folder that I created or do I have to do something else to see them in the folder. I don't want them to go away once I have added these. I'm new to Inventor so I apologize.
bradeneuropeArthur
You will need them to add to the material and appearance style library.
First you need to create a read-write library (material and aprearance).
Then add these materials from your part-document to the libraries.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
sattju
I believe I am doing this right then. I have attached a screenshot of what it looks like.
bradeneuropeArthur
That looks fine!
Are you having a Appearance Library too (read Write)?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
sattju
I doubled checked and yes, the appearance works with the material and changes color when I assign it. Thanks for your help!
