Many parameters to manage
I' ve to pass about 1500 parameters from linked excel table to Inventor USER parameter table. Now I'm doing it manually, trough options "add to user parameter" in parameter dialog box. Is there a quicker method? Is there a VB routine to use? If somebody as a solution I will be very happy.
Enrico MOndani
Why would you want to make them all
userparameters?
If you are making ALL the linked parameters
userparameters, why not just delete the whole folder of your linked table? All
the parameters you use in equations will end up in your userparameters. Beware,
all not-used parameters will be deleted!
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I'
Enrico
MOndani
