CreateObject Error - Inventor and VB6
I have created a class that uses CreateObject /GetObject to open an
application. Every time the class creates a new instance of the application,
when the class exits it returns an Application Error The error states the
memory location and " "The memory could not be "read".
When I place a break point in the code the error does not occur. So I placed
an OK Only message box in the Terminate event this also prevented the error.
I also used a loop and this worked but not a good solution.
I am trying to find a solution that does not require operator intervention
has anyone any ideas.
'GetObject("", "Inventor.Application") always creates a new Instance
The basic code:
Set oApp = GetObject("", "Inventor.Application")
Set oDoc = oApp.Documents.Open("C:\BradTest.ipt")
oApp.Visible = True
Dim oPartDef As PartComponentDefinition
Set oPartDef = oDoc.ComponentDefinition
Code to make changes
oDoc.Save
oDoc.Close
oApp.Visible = False
paulschuepbach
Alvin,
here's a sample to create/get a object from Inventor for Excel:
' at the beginning of Form_Load() Sub:
On Error Resume Next
Set oEx = GetObject(, "Excel.Application")
' Error, if Excel is not already running, then Create Excel-object
If Err.Number <> 0 Then
Set oEx = CreateObject("Excel.Application")
Err.Clear
oEx.Visible = True
I think this will work the other way around (from any application to Inventor) too.
The other thing: at the end of your code, you just set yout Inventor-object to invisible - the object
is still alive. Do the following at the end:
Set oApp = Nothing
The object ist terminated. Otherwise, Inventor ist just invisible, but if you watch the
Task-Manager, Inventor.exe is still alive and this will crate a error (for each 'alive'
Inventor object.
Note the following: If your application crashes somewhere in the middle of it's code, the
Inventor object will stay alive and you will have to kill it via TaskManager.
Hope this helps,
Best, Paul
