Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Macro to export "File name" and "iProperty - Keyword" to a XLS database. Exists? Sugestions?
2 REPLIES 2
FilipeMais
136 Views, 2 Replies
Hello everybody,
In my company I am updating all old drawings to Inventor files.
Thousands of drawings to update and RENAME is also a condition.
To help the colleagues in the warehouse I thought to create a table with the "New names" and the "Old names".
The "Old name" are written in "iProperty - Keyword".
Is there any macro that could be added in Inventor that could feed/create a database with that information?
Would be great if I had a button on Inventor that charge that table after save the file and stored in Vault.
Table with two columns:
New file name - Old file name.
Thanks in advance!
All the best,
Filipe
2 REPLIES 2
JelteDeJong
in reply to: FilipeMais
If you don't mind working with CSV files. (Which can also be opened with Excel) then you could use this iLogic rule.
' Change the path on the next line to whatever you need.
Dim exportedFilesPath = "c:\temp\test.csv"
Dim doc As Document = ThisDoc.Document
Dim prop = doc.PropertySets.Item("Inventor Summary Information").Item("Keywords")
Dim fileInfo As New System.IO.FileInfo(exportedFilesPath)
Dim excelRow = String.Format("{0}|{1}", doc.FullFileName, prop.Value)
Dim lines As New List(Of String)
If (Not System.IO.File.Exists(exportedFilesPath)) Then
    lines.Add("sep=|")
lines.Add(excelRow)
System.IO.File.AppendAllLines(exportedFilesPath, lines)
Jelte de Jong
Blog: hjalte.nl - github.com
FilipeMais
@JelteDeJong Muito obrigado!!! Funciona muito bem!
Para evitar o texto "C:/Workplace/Designs..." tentei substituir a variável "Inventor Summary Information" pela variável "Part number", mas aparece uma mensagem de erro.
Qual variável deve ser escrita ali?
Atenciosamente,
Filipe
