Macro to export "File name" and "iProperty - Keyword" to a XLS database. Exists? Sugestions?
FilipeMais
FilipeMais
Hello everybody,
In my company I am updating all old drawings to Inventor files.
Thousands of drawings to update and RENAME is also a condition.
To help the colleagues in the warehouse I thought to create a table with the "New names" and the "Old names".
The "Old name" are written in "iProperty - Keyword".
Is there any macro that could be added in Inventor that could feed/create a database with that information?
Would be great if I had a button on Inventor that charge that table after save the file and stored in Vault.
Table with two columns:
New file name - Old file name.
Thanks in advance!
All the best,
Filipe
JelteDeJong
If you don't mind working with CSV files. (Which can also be opened with Excel) then you could use this iLogic rule.
' Change the path on the next line to whatever you need.
Dim exportedFilesPath = "c:\temp\test.csv"
Dim doc As Document = ThisDoc.Document
Dim prop = doc.PropertySets.Item("Inventor Summary Information").Item("Keywords")
Dim fileInfo As New System.IO.FileInfo(exportedFilesPath)
Dim excelRow = String.Format("{0}|{1}", doc.FullFileName, prop.Value)
Dim lines As New List(Of String)
If (Not System.IO.File.Exists(exportedFilesPath)) Then
    lines.Add("sep=|")
End If
lines.Add(excelRow)
System.IO.File.AppendAllLines(exportedFilesPath, lines)
Jelte de Jong
Blog: hjalte.nl - github.com
FilipeMais
@JelteDeJong Muito obrigado!!! Funciona muito bem!
Para evitar o texto "C:/Workplace/Designs..." tentei substituir a variável "Inventor Summary Information" pela variável "Part number", mas aparece uma mensagem de erro.
Qual variável deve ser escrita ali?
Atenciosamente,
Filipe
