Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
IV2009 - Purge styles?
4 REPLIES 4
307 Views, 4 Replies
Is there an API command to purge styles from a drawing? I'm writing a drawing "cleaner" to get rid of unused borders, symbols, etc. I'd like to also purge styles if possible. TIA
4 REPLIES 4
The Style.Delete method is the equivalent of purge. It works only on local
(or locally modified) styles and fails for library styles.
Sanjay-
amattos
This may help you cleaning Drawing Resource up
Public Sub IDW_DelAllDrawingResources()
' If the active document is not a DRAWING , inform the user and stop the macro
msgPrm1 = " This Macro Only Works with Drawings Documents "
msgPrm2 = " Please open a Drawing "
msgTit = "Wrong Active Document Type"
Prm1 = Len(msgPrm1) + 4
Prm2 = Len(msgPrm2) + 4
Tit = Len(msgTit)
cmsgPrm2 = String((Prm1 - Prm2) / 2, Chr(32)) & msgPrm2
cmsgTit = String((Prm1 - Prm2) / 2, Chr(32)) & msgTit
'check if the active document is a drawing document
If ThisApplication.ActiveDocumentType = kDrawingDocumentObject Then
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
' If iNSTR(1,
' MsgBox "The Active Document is a Template this macro will terminate", vbExclamation, "Wrong Active Document Type"
'End If
Else
MsgBox msgPrm1 & Chr(13) & Chr(13) & cmsgPrm2, vbExclamation, cmsgTit
Dim oPane As BrowserPane
Set oPane = oDoc.BrowserPanes.ActivePane
Dim oDocNode As BrowserNode
Set oDocNode = oPane.TopNode
Dim oDrawingResourceNode As BrowserNode
Set oDrawingResourceNode = oDocNode.BrowserNodes.Item("Drawing Resources")
Dim oSheetFormatsNode As BrowserNode
Set oSheetFormatsNode = oDrawingResourceNode.BrowserNodes.Item("Sheet Formats")
Dim oBordersNode As BrowserNode
Set oBordersNode = oDrawingResourceNode.BrowserNodes.Item("Borders")
Dim oTitleBlocksNode As BrowserNode
Set oTitleBlocksNode = oDrawingResourceNode.BrowserNodes.Item("Title Blocks")
Dim oSketchedSymbolsNode As BrowserNode
Set oSketchedSymbolsNode = oDrawingResourceNode.BrowserNodes.Item("Sketched Symbols")
' Loop thru each resource node
oDrawingResourceNode.DoSelect
oDrawingResourceNode.EnsureVisible
oDrawingResourceNode.Expanded = True
Dim oSheetFormatNode As BrowserNode
For Each oSheetFormatNode In oSheetFormatsNode.BrowserNodes
' Select the node in the browser.
oSheetFormatNode.DoSelect
oSheetFormatNode.Expanded = True
' Execute the delete command.
'Debug.Print oSheetFormatNode.FullPath
ThisApplication.CommandManager.ControlDefinitions.Item("AppDeleteCmd").Execute
Next
Dim oBorderNode As BrowserNode
For Each oBorderNode In oBordersNode.BrowserNodes
oBorderNode.DoSelect
oBorderNode.Expanded = True
'Debug.Print oBorderNode.FullPath
Next
Dim oTitleBlockNode As BrowserNode
For Each oTitleBlockNode In oTitleBlocksNode.BrowserNodes
oTitleBlockNode.DoSelect
oTitleBlockNode.Expanded = True
'Debug.Print oTitleBlockNode.FullPath
Next
Dim oSketchedSymbolNode As BrowserNode
For Each oSketchedSymbolNode In oSketchedSymbolsNode.BrowserNodes
oSketchedSymbolNode.DoSelect
oSketchedSymbolNode.Expanded = True
'Debug.Print oSketchedSymbolNode.FullPath
Next
'oDoc.Save
End Sub
Thanks avmattos, below is the solution I came up with (note no ControlDefinitions.Execute method)
Public Sub DrawingCleanDrawingResources()
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = GetActiveDrawing
If oDrawDoc Is Nothing Then Exit Sub
'get rid of sheet formats
Dim oSF As SheetFormat
For Each oSF In oDrawDoc.SheetFormats
oSF.Delete
Next oSF
'get rid of borders
Dim oBorderDef As BorderDefinition
For Each oBorderDef In oDrawDoc.BorderDefinitions
If Not oBorderDef.IsReferenced And Not oBorderDef.IsDefault Then
oBorderDef.Delete
Next oBorderDef
'get rid of titleblocks
Dim oTBDef As TitleBlockDefinition
For Each oTBDef In oDrawDoc.TitleBlockDefinitions
If Not oTBDef.IsReferenced Then
oTBDef.Delete
Next oTBDef
'get rid of symbols
Dim oSymbol As SketchedSymbolDefinition
For Each oSymbol In oDrawDoc.SketchedSymbolDefinitions
If Not oSymbol.IsReferenced Then
oSymbol.Delete
Next oSymbol
End Sub
Public Function GetActiveDrawing() As DrawingDocument
If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
Set GetActiveDrawing = ThisApplication.ActiveDocument
Else
MsgBox "Must have a drawing active", vbOKOnly, "Error"
End Function
amattos
Josh,
Thanks for a lean way to do it. Good job. I did not try it yet but my guess is your code runs faster.
Anderson Mattos
Technology Administrators
