Issues with my first macro
- Mute
- Permalink
- Report
I am just getting into using Inventor's API, and I would like some help getting in the right direction.
I found a basic Autosave macro online:
Public Sub TimerSetting()
i = InputBox("Input Timer", "Timer Form")
i = i * 60
If i > 600 Then
MsgBox ("30min MAXIMUM, TIMER SET TO 30min")
i = 600
ElseIf i < 60 Then
MsgBox ("1min MINIMUM, TIMER SET TO 1min")
i = 60
End If
Dim SetTimer, Start, Finish, TotalTime
SetTimer = i ' Set duration.
Start = Timer ' Set start time.
Do While Timer < Start + SetTimer
DoEvents ' Yield to other processes.
Loop
Finish = Timer ' Set end time.
TotalTime = Finish - Start ' Calculate total time.
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
oDoc.Save2 (True)
MsgBox "DOCUMENT HAS BEEN SAVED"
End SubIt would run as long as you didn't cancel anything, but I wanted to set some more boundaries:
1) I want to look at the active document, identify its type, and tell the user that it should only be used in drawing documents
2) I want to rune the timer, basically the way it is written above, and save the previously identified document [ I want to be able to switch between multiple part/assembly documents while timer is running and save the drawing upon returning after the timer is done]
3) I want to ask the user if they would like to restart the timer, and do so with the same time limit
Here is what I've come up with so far:
Public Sub AUTOSAVE()
' Connect to a running instance of Inventor.
Dim invApp As Inventor.Application
invApp = System.Runtime.InteropServices.Marshal.GetActiveObject _
("Inventor.Application")
' Get the Documents collection.
Dim oDocs As Inventor.Documents
oDocs = invApp.Documents
' Get the Active part document.
Dim ThisDoc As Inventor.Documents
ThisDoc = invApp.ActiveDocument
If ThisDoc = Inventor.DrawingDocuments Then 'Check if user is in a drawing document
GoTo 100
Else
o = MsgBox("I would recommend only using the AUTOSAVE macro in drawing documents. Would you like to ignore this warning?", "Caution", MessageBoxButtons.YesNo)
If o = vbYes Then
MsgBox "Good Luck..."
GoTo 100
Else
MsgBox "Good Choice!"
GoTo 102
End If
End If
100 'Requesting user input for timer duration
i = InputBox("This timer has a limited range: 1-30(min).", "DRAFTING AUTOSAVE", i = 600) '10 minute default
i = i * 60
If i > 1800 Then
MsgBox ("This timer has a limited range: 1-30(min), timer was set to 30min.")
i = 1800
ElseIf i < 60 Then
MsgBox ("This timer has a limited range: 1-30(min), timer was set to 1min.")
i = 60
ElseIf i = vbCancel Then
MsgBox "Timer was cancelled."
GoTo 102
End If
101 'Executing timer
SetTimer = i ' Settting duration.
Start = Timer ' Setting start time.
Loop
Finish = Timer ' Settting end time.
TotalTime = Finish - Start ' Calculating total time.
ThisDoc.Save2 (True) 'Saving file at end of timer
'Asking user to run timer again
r = MsgBox("The document has been saved sucessfully, would you like to restart the timer?", "DRAFTING AUTOSAVE", MessageBoxButtons.YesNo)
If r = vbYes Then
MsgBox "Timer will restart now."
GoTo 101
Else
MsgBox "Timer is ended. Happy Modeling!"
GoTo 102
End If
102
End SubMy issue is that the debugger won't get past the 4th line, where I set invApp = to the application. I have tried using the ThisApplication designation but it doesn't like that either.
Can someone point me in the right direction?
