Is there a hot key or short cut for jumping between sheets in an .idw
Hi All,
Just wanted to know if there is a hot key or short cut for jumping between sheets in an .idw? just to make it a lot quicker in each drawing to navigate between the sheets. I was hoping the pg up and pg down pages would do this but unfortunately they do not.
Any help or news on the subject would be appreciated
bradeneuropeArthur
I have an add in for it.
Do you like to have it?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Jesper_S
Hi.
Thats sounds like a great tool...
Can i borrow it to?
//Jesper
//Jesper
bradeneuropeArthur
I have programmed it my selves.
What version of inventor do you use?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Jesper_S
I use IV 2017.
//Jesper
//Jesper
bradeneuropeArthur
Do you like to have the addin?
Please send me a private message so I will not forget.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Hi bradeneurope,
yes please i would like the add in if it is still available
Thank you
