Is it possible to access the Studio Animation?
2 REPLIES 2
417 Views, 2 Replies
I got a serious situation that is I need to change the End Value in Animate Parameter.
I can only access to AnimationFavorites.Item:
' Find the Studio Add-In
Dim oStudioAddin As ApplicationAddIn
Dim oAddin As ApplicationAddIn
For Each oAddin In ThisApplication.ApplicationAddIns
If oAddin.ClassIdString = "{F3D38928-74D1-4814-8C24-A74CE8F3B2E3}" Then
Set oStudioAddin = oAddin
Exit For
End If
Next
If oStudioAddin Is Nothing Then
MsgBox "Inventor Studio Addin not loaded."
Exit Sub
End If
' Get the Inventor Studio object.
Dim oInventorStudio
Set oInventorStudio = oStudioAddin.Automation
' Activate the Studio environment.
Dim oStudioEnvironment As Environment
Set oStudioEnvironment = oInventorStudio.Activate
Dim oAnimationManager
Set oAnimationManager = oInventorStudio.animationmanager
Dim oAnimationFavorites
Set oAnimationFavorites = oAnimationManager.animationfavorites
Dim oAnimationFavoriteItem
For Each oAnimationFavoriteItem In oAnimationFavorites
If oAnimationFavoriteItem.Name = "a" Then
oAnimationFavoriteItem.Value = A/10
ElseIf oAnimationFavoriteItem.Name = "b" Then
oAnimationFavoriteItem.Value = B/10
ElseIf oAnimationFavoriteItem.Name = "c" Then
oAnimationFavoriteItem.Value = C/10
End If
Next
So, the question is "Is it possible to access the End Value of Animate Parameter?"
Many thanks in advance!
Exit For
End If
Next
Exit Sub
End If
Dim oInventorStudio
End If
Next
2 REPLIES 2
Evenwhen I change the Parameter in Favorites already. It doesn't really make sense because the animation is the same.
What I want is to change the animation to suitable with the macro.
Please help me to solve this!
I really cannot find out any thing for this situation. Thanks.
Please help me to show this problem!Smiley Embarassed
