I would like to be able to concatenate the title of my part using iLogic. I would like it to read this:
"TEXT 12.5in TEXT (1 1/2 x12.5 x 20)"
The "12.5in", "12.5" and the "20" are all variables that I am setting with ilogic. As the part changes so do these variables. Its probably something very simple, but I cant get it to do it.
I have tried this, but it gives me an error.
iProperties.Value("Summary", "Title")="TEXT"Cutlength"TEXT"Width "x" total"
Solved by Curtis_Waguespack. Go to Solution.
Hi karthur1,
In addtion to Paul's answer, this link from the Inventor Customization forum provides an example as well:
I hope this helps.
Curtis
I was way over-thinking this. I could actually do what I needed this time using formulas in my iproperties. I can see this being useful later though.
Thanks.
There are times when I need to populate the iproperty fields with iLogic rather than with a formula in iproperty.
When that is the case, here is how it can be populated.
If you need to format the expression as fractional, here is a way to do that also. Use the RoundToFraction function.
