- Mute
- Permalink
- Report
I have created an iPart factory in which I wrote an iLogic to convert the weight to a whole number and write it as a custom property. The iLogic rule has been applied to the Event Trigger "Before Save". This set up works fine on the factory and all of my other parts.
Within the member, it seams as if the the iLogic rule does not push to the generated member, but the member remembers the event trigger so it continues to give the error that it cannot find the rule.
Am I doing something wrong, is this a glitch in this part, or is this an issue with Inventor 2020?
