Can someone help me to find a list of VBA commands for selection ("pick") filters?
For example for select lines is: kSketchCurveLinearFilter
For face and edge selection is: kPartFaceFilter, kPartEdgeFilter
I can't find for work features, for work point selection? Is there a filter or I have to watch work points as objects and use ".Select(obj)"?
Danijel
Solved by Jef_E. Go to Solution.
Enumeration of the selection filters.
Name | Value | Description |
kAllCircularEntities | 18435 | All circular entities filter. |
kAllCustomGraphicsFilter | 18436 | All custom graphics. |
kAllEntitiesFilter | 18439 | All entities filter(all entities should be selectable). |
kAllLinearEntities | 18433 | All linear entities filter. |
kAllPlanarEntities | 18432 | All planar entities filter. |
kAllPointEntities | 18434 | All point entities filter. |
kAssemblyFeatureFilter | 16646 | Assembly feature filter. |
kAssemblyLeafOccurrenceFilter | 16643 | Assembly leaf occurrence filter. |
kAssemblyOccurrenceFilter | 16640 | Assembly occurrence filter. |
kAssemblyOccurrencePatternElementFilter | 16645 | Assembly occurrence pattern element filter. |
kAssemblyOccurrencePatternFilter | 16644 | Assembly occurrence pattern filter. |
kCustomBrowserNodeFilter | 18437 | Custom browser node. |
kDrawingAutoCADBlockDefinitionFilter | 16923 | Drawing Block Definition filter. |
kDrawingAutoCADBlockFilter | 16922 | Drawing Block Reference filter. |
kDrawingBalloonFilter | 16906 | Drawing balloon filter. |
kDrawingBorderDefinitionFilter | 16909 | Drawing border definition filter. |
kDrawingBorderFilter | 16913 | Drawing Border instance filter. |
kDrawingCenterlineFilter | 16915 | Drawing Centerline filter. |
kDrawingCentermarkFilter | 16916 | Drawing Centermark filter. |
kDrawingCurveSegmentFilter | 16914 | Drawing curve segment filter. |
kDrawingCustomTableFilter | 16905 | Drawing custom table filter. |
kDrawingDefaultFilter | 16896 | Drawing default filter. |
kDrawingDimensionFilter | 16900 | Drawing dimension filter. |
kDrawingFeatureControlFrameFilter | 16918 | Drawing feature control frame filter. |
kDrawingHoleTableFilter | 16902 | Drawing hole table filter. |
kDrawingHoleTagFilter | 16903 | Drawing hole tag filter. |
kDrawingNoteFilter | 16899 | Drawing note filter. |
kDrawingOriginIndicatorFilter | 16920 | Drawing OriginIndicator filter. |
kDrawingPartsListFilter | 16901 | Drawing parts list filter. |
kDrawingRevisionTableFilter | 16904 | Drawing revision table filter. |
kDrawingSheetFilter | 16897 | Drawing sheet filter. |
kDrawingSheetFormatFilter | 16917 | Drawing sheet format filter. |
kDrawingSketchedSymbolDefinitionFilter | 16908 | Drawing sketched symbol definition filter. |
kDrawingSketchedSymbolFilter | 16907 | Drawing sketched symbol filter. |
kDrawingSurfaceTextureSymbolFilter | 16919 | Drawing surfacetexture symbol filter. |
kDrawingTitleBlockDefinitionFilter | 16910 | Drawing title block definition filter. |
kDrawingTitleBlockFilter | 16912 | Drawing title block instance filter. |
kDrawingViewFilter | 16898 | Drawing view filter. |
kDrawingViewLabelFilter | 16921 | Drawing surfacetexture symbol filter. |
kFeatureDimensionFilter | 18438 | Feature dimension filter. |
kPartBodyFilter | 15890 | Part body filter. |
kPartDefaultFilter | 15886 | Part default filter. |
kPartEdgeCircularFilter | 15874 | Part edge circular filter. |
kPartEdgeFilter | 15873 | Part edge filter. |
kPartEdgeLinearFilter | 15875 | Part edge linear filter. |
kPartEdgeMidpointFilter | 15876 | Part edge midpoint filter. |
kPartFaceConicalFilter | 15880 | Part face conical filter. |
kPartFaceCylindricalFilter | 15879 | Part face cylindrical filter. |
kPartFaceFilter | 15877 | Part face filter. |
kPartFacePlanarFilter | 15878 | Part face planar filter. |
kPartFaceSphericalFilter | 15882 | Part face spherical filter. |
kPartFaceToroidalFilter | 15881 | Part face toroidal filter. |
kPartFeatureFilter | 15884 | Part feature filter. |
kPartSurfaceFeatureFilter | 15885 | Part surface feature filter. |
kPartVertexFilter | 15883 | Part vertext filter. |
kPointCloudFilter | 15891 | Point cloud filter. |
kPointCloudPointFilter | 15892 | Point cloud point filter. |
kSketch3DCurveCircularFilter | 17666 | 3D Sketch curve circular filter. |
kSketch3DCurveEllipseFilter | 17667 | 3D Sketch curve ellipse filter. |
kSketch3DCurveFilter | 17664 | 3D Sketch curve filter. |
kSketch3DCurveLinearFilter | 17665 | 3D Sketch curve linear filter. |
kSketch3DCurveSplineFilter | 17668 | 3D Sketch curve spline filter. |
kSketch3DDefaultFilter | 17670 | 3D Sketch default filter. |
kSketch3DDimConstraintFilter | 17672 | 3D Sketch dimension constraint filter. |
kSketch3DObjectFilter | 17671 | 3D Sketch filter. |
kSketch3DPointFilter | 17669 | 3D Sketch point filter. |
kSketch3DProfileFilter | 17673 | 3D Sketch profile filter. |
kSketchBlockDefinitionFilter | 16141 | SketchBlock definition filter. |
kSketchBlockFilter | 16142 | SketchBlock filter. |
kSketchCurveCircularFilter | 16131 | Sketch curve circular filter. |
kSketchCurveEllipseFilter | 16132 | Sketch curve ellipse filter. |
kSketchCurveFilter | 16129 | Sketch curve filter. |
kSketchCurveLinearFilter | 16130 | Sketch curve linear filter. |
kSketchCurveSplineFilter | 16133 | Sketch curve spline filter. |
kSketchDefaultFilter | 16135 | Sketch default filter. |
kSketchDimConstraintFilter | 16128 | Sketch dimension constraint filter. |
kSketchImageFilter | 16137 | SketchImage filter. |
kSketchObjectFilter | 16136 | Sketch filter. |
kSketchPointFilter | 16134 | Sketch point filter. |
kSketchProfileFilter | 16139 | 2D Profile filter. |
kSketchProjectedCutFilter | 16140 | ProjectedCut filter. |
kSketchTextBoxFilter | 16138 | Sketch TextBox filter. |
kUserCoordinateSystemFilter | 16387 | UserCoordinateSystem Filter. |
kWorkAxisFilter | 16384 | Work axis filter. |
kWorkPlaneFilter | 16385 | Work plane filter. |
kWorkPointFilter | 16386 | Work point filter. |
Introduced in Inventor version 5
That's it!
Thank you a lot Jef.
Regards
Danijel
Hi Jef,
I am Harish, CAD Design Engineer. I was looking for the below Pick filter list from many days, thank you for this usefull post.
I need one suggestion from you on this, I am working on a VBA, where i need to pick/Select only the Hole features in an assembly or part , please suggest me which filter i can use to select only the HOLE feature (kPartFaceCylindricalFilter doesn't work for me , bcoz, this filter selects even bend radius or fillet in my part)
Kindly need your suggestion.
Thank you..
Harish Kumar M
There is no specific filter for HOLE features only. You can use kPartFeatureFilter and then validate the user selection.
If TypeOf SelectedFeature = HoleFeature Then ... End If
Sir,
I am trying to pick all holes in part and create work axis for each hole by ilogic, But i am not getting exact ilogic code to do this.
Please need your suggestion or sample ilogic code to do this.
Thank you..
Harish
Hello @Anonymous,
As @Jef_E said, you have to use "kPartFeatureFilter" to get all features and after you need to filter Hole Features by it's type.
Here is the VBA code:
Public Sub createHoleAxis() Dim oPartDoc As PartDocument Set oPartDoc = ThisApplication.ActiveDocument Dim oCompDef As ComponentDefinition Set oCompDef = oPartDoc.ComponentDefinition Dim oFeat As PartFeature Dim oWorkAxis As WorkAxis Dim i As Integer For i = 1 To oCompDef.Features.Count Set oFeat = oCompDef.Features(i) If TypeOf oFeat Is HoleFeature Then Set oWorkAxis = oCompDef.WorkAxes.AddByRevolvedFace(oFeat.Faces.Item(1), False) End If Next i End Sub
With small modification, you can adapt it to iLogicL:
Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument Dim oCompDef As ComponentDefinition oCompDef = oPartDoc.ComponentDefinition Dim oFeat As PartFeature Dim oWorkAxis As WorkAxis Dim i As Integer For i = 1 To oCompDef.Features.Count oFeat = oCompDef.Features(i) If TypeOf oFeat Is HoleFeature Then oWorkAxis = oCompDef.WorkAxes.AddByRevolvedFace(oFeat.Faces.Item(1), False) End If Next i
Hope this helps!
Best,
Danijel
Thanks for the posting.
I would like to select the center of a circle (or center of arc).
Could you help, please.
