Inventor using iLogic to change model tolerance of hole feature
bill.leonard
bill.leonard
Moved from original post for clarity:
Using iLogic to change model tolerance
I have a problem similar to the one described in the previous post.  I am using the following statements to set the tolerance for a hole feature:
Dim ThisHole As HoleFeature
Set ThisHole = oPartDoc.SelectSet.Item(1)
Call ThisHole.HoleDiameter.Tolerance.SetToFits(kLimitsFitsShowSizeTolerance, "P7", "")
As the screenshot below shows, everything appears to work OK when I execute the statement.
The upper/lower limits show as 7.991/7.976, as they should.  However, as the picture below shows, when I dimension the hole on a drawing with the "use tolerance from part" option, the deviations applied to the diameter are off by a factor of 10.
I assume this is due to Inventor's internal unit being centimeters instead of millimeters, but I can't figure out how to correct the issue in my code, since there is no place to specify units in the parameters.
Can anyone help me out with this?
(Apologies if I have posted this in an inappropriate location.  I am new to this forum, and am unfamiliar with the proper protocols.)
bradeneuropeArthur
Same issue in inventor 2018.
Seems to be a bug....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
This will reset the value by 1 to the default value:
Please try this.
Public Sub main()
Dim opartdoc As PartDocument
Set opartdoc = ThisApplication.ActiveDocument
Set ThisHole = opartdoc.SelectSet.Item(1)
Dim Express As Variant
Express = ThisHole.HoleDiameter.Value
Dim h As Tolerance
Set h = ThisHole.HoleDiameter.Tolerance
Call h.SetToFits(kLimitsFitsShowSizeTolerance, "P8", "")
'Reset the value......
ThisHole.HoleDiameter.Value = 1
'fill in the default value again.......
ThisHole.HoleDiameter.Value = Express
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bill.leonard
Excellent!  This worked perfectly.
My only issue now is the way the hole value displays in the inventor browser.
As the picture below shows, the hole whose tolerance was set by the code (Hole 1) now displays with 8 trailing zeros, whereas holes dimensioned through Inventor (Hole 2 & Hole 3) display with fewer trailing zeros.
Do you happen to have any thoughts on how this display issue might be corrected?  If not, it's not that big of a deal.  I still really appreciate your solution to the actual problem!
bradeneuropeArthur
Change the precision of the parameter.
I will take a look for you ASAP next week.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
