All,
Good afternoon! I'm after more of a "can it be done" answer versus some specific code, but I'm wondering if it is possible to create / orient BIM Connectors with iLogic? It looks like this is possible, based on my searching of the API help, but I wanted to check.
Follow-up question, regarding the Configurator 360 (and please point me in the right direction if this is the wrong forum for this question). Does Configurator 360 allow for advanced code, like the BIM Connectors logic from above?
If anyone has any questions, please do not hesitate to contact me and I'll be happy to respond. Just trying to figure out if something is possible before I devote any time to actually figuring it out. Thanks in advance for any assistance, hope all is well and have a most blessed day!
Peace,
Pete
Solved by JelteDeJong. Go to Solution.
if i look at this posts i expect it can be done.
for your follow up question. i have never worked with Configurator 360 but the it looks promising:
But if that does not work for you then you could switch to autodesk forge. then you need to create an addin that does the work. (and then you will have all the advanced code/api that you need for sure) Just a few weeks a go there was a webinair on that topic. have a look at this: https://www.youtube.com/watch?v=RRgahfnnbWo
(Just another guy on a couch...)
Jelte de Jong
Blog: hjalte.nl - github.com
