Hi There,
I want insert a Custom Property into a Textbox as a field, see below Screenshot.
In that way it will change as I change the part.
Goal: I want to put the filenumber (custom Iporperty) into a textbox as a field.
Then when I save the file as another number this field will update.
My Problem is that I don't know how to insert this field into the textbox.
The code that I have thisfar is:
Sub Main() '===================== DECLERATIONS =============================== ' a reference to the currently active document. ' This assumes that it is a part document. Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument Dim oCompDef As PartComponentDefinition oCompDef = oPartDoc.ComponentDefinition ' Set a reference to the transient geometry object. Dim oTransGeom As TransientGeometry oTransGeom = ThisApplication.TransientGeometry Dim oPartCompDef As PartComponentDefinition oPartCompDef = ThisApplication.ActiveDocument.ComponentDefinition oModel=ThisDoc.ModelDocument 'Creating Custom IProperty with filenumber in it calling it Tekeningnummer iProperties.Value("Custom", "Tekeningnummer") = ThisDoc.FileName(False) 'false = without extension iProperties.Value("Custom", "Tekeningnummer") = (Left(ThisDoc.FileName(False),14)) 'Get the Property ID For these custom iProperties From the model referenced By the view o_iPropID_1 = oModel.PropertySets.Item("Inventor User Defined Properties").Item("Tekeningnummer").PropId 'format the custom iproperty string and add the property ID oString1 = "<Property Document='model' PropertySet='User Defined Properties' " _ & "Property='FCE_PartNumber' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='" _ & o_iPropID_1 & "'>FCE_PartNumber</Property><Br/>" End Sub
Hope you can help me with this.
PS: This is to complete my engraving rule to automaticly update the engraving when copying the part to another part.
"Ilogic Rule To Mark Textbox on a face with a specific direction for Engraving
Solved by jeanB99VC. Go to Solution.
You can added the iproperty by general text, see api sample for vba here for updating exisiting drawings.
Here is the ilogic version of the same code with a sub routine to retrieve an existing iprop formatted text.
Or the alternate method is to add it in the drawing template manually and then just change the iproperty by code. No need for the formatted text then.
Why you need automation? this case is simple, just use leader note and assign it.
Hi There,
I'm not talking about a drawing.
I want the textfield (Custom Property) to be placed in a sketch on the face of a sheetmetalpart as a field.
Then I can turn it into a mark for engraving. This rule has already been made in another post from me.
I don't understand the help in inventor itself
Goal: I'm looking for the specific method to insert the custom property as a field in the textbox on the face of a part.
@Ilogic Rule To Mark Textbox on a face with a specific direction for Engraving
Ok I see it's a part. Your previous post is doing exactly that at this area of the code
Create a textbox in the Sketch to place the Iporp Tekeningnummer ====================
Once the textbox is created then set the formatted text like
oTextBox.FormattedText= oString1
Hi Alan,
I'm sorry but I'm not sure what to do where to change what. I have the idea that I'm close but not close enough 🙂
Is it possible for you to change my rule below so the textbox is filled with the Field of the custom prop instead of the value.
That way if the part is saved as another name the textbox automaticly changes. That was my goal for this rule
I've pasted the rule for engraving below.
Thank you in advance !
Sub Main() '===================== DECLERATIONS =============================== ' a reference to the currently active document. ' This assumes that it is a part document. Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument Dim oCompDef As PartComponentDefinition oCompDef = oPartDoc.ComponentDefinition ' Set a reference to the transient geometry object. Dim oTransGeom As TransientGeometry oTransGeom = ThisApplication.TransientGeometry Dim oPartCompDef As PartComponentDefinition oPartCompDef = ThisApplication.ActiveDocument.ComponentDefinition '========================================================================= 'Find Sketch named already For marking so the user can delete it For Each oSketchCheck As PlanarSketch In oPartCompDef.Sketches If oSketchCheck.Name = "MarkingSketch" Then MessageBox.Show("A sketch named " & oSketchCheck.Name & " already exists. Please Delete this sketch", "Controle op MarkingSketch") Return End If Next 'Select Face and Edges to place the textbox in a certain direction = Van JelteDejong Forum Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface to Place Textbox") Dim oHorizontalEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select Horizontal Edge of Tekeningnummer on Face") Dim orignVertex As Vertex = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter, "Select Point (vertex) on the plane") Dim testVertex As Vertex = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter, "Select a 2nd Point (vertex) that is on a positive point in the sketch and not on the axes") 'Add Sketch and set sketch origin point to the stopVertex of the FrontEdge, this is where the TextBox starts Dim oSketch As PlanarSketch = oPartCompDef.Sketches.Add(oFace, False) oSketch.AxisEntity = oHorizontalEdge oSketch.OriginPoint = orignVertex oSketch.NaturalAxisDirection = True 'Check if the testVertex has positive coordinates = Van JelteDejong Forum Dim testPoint As Point2d = oSketch.ModelToSketchSpace(testVertex.Point) If (testPoint.X <= 0 Or testPoint.Y <= 0) Then oSketch.NaturalAxisDirection = False End If testPoint = oSketch.ModelToSketchSpace(testVertex.Point) Dim positiveQuadrantIsOnPlane = (testPoint.Y >= 0) ' ===================== Create a Custom Parameter in Iproperties "Tekeningnummer"====================== 'Creating Custom IProperty with filenumber in it calling it Tekeningnummer iProperties.Value("Custom", "Tekeningnummer") = ThisDoc.FileName(False) 'false = without extension iProperties.Value("Custom", "Tekeningnummer") = (Left(ThisDoc.FileName(False),14)) 'Creating a UserParameter Where the Tekeningnummer value Is put In Dim PropValue As String = iProperties.Value("Custom", "Tekeningnummer") 'updates the user-defined Text Parameter TagName = PropValue '================================ Create a textbox in the Sketch to place the Iporp Tekeningnummer ==================== ' Create Text With simple String As Input. Since this doesn't use ' any Text Overrides, it will Default To the active Text Style. Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry Dim sText As String sText = TagName Dim oTextBox As Inventor.TextBox If (positiveQuadrantIsOnPlane) Then oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.3, 0.5), sText) Else oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.3, -0.3), sText) End If 'Changing Font and/or size Dim dTextSize As Double dTextSize = 0.4 ' value is in cm. equals .125 in Dim sTextFont As String ' sTextFont = "SIMPLEX" oTextBox.FormattedText = "<StyleOverride Font = '" & sTextFont & "' FontSize = '" & dTextSize & "'>" & _ sText & "</StyleOverride>" '==================== Creating an Objectcollection to be Marked ====================== Dim oSketchObjects As ObjectCollection oSketchObjects = ThisApplication.TransientObjects.CreateObjectCollection ' Get all entities in the sketch Dim oSketchText As Inventor.TextBox For Each oSketchText In oSketch.TextBoxes oSketchObjects.Add(oSketchText) Next '==================== Creating the Mark on the textbox ====================== Dim oMarkFeatures As MarkFeatures oMarkFeatures = oCompDef.Features.MarkFeatures ' Get a mark style. Dim oMarkStyle As MarkStyle oMarkStyle = oPartDoc.MarkStyles.Item(1) ' Create mark definition. Dim oMarkDef As MarkDefinition oMarkDef = oMarkFeatures.CreateMarkDefinition(oSketchObjects, oMarkStyle) ' Create a mark feature. Dim oMark As MarkFeature oMark = oMarkFeatures.Add(oMarkDef) '==================== 'Naming the sketch And markfeature For detection In future oSketch.Name = "MarkingSketch" oMark.Name = "Gravering Tekeningnummer" Call ZoomAll oPartDoc.Save End Sub Sub ZoomAll 'zoom all, this to be sure the part is in ISOmetrich position saved so it is ISO visible in explorer ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute End Sub
Here is what is working. The parameter field is added via formatted text. There is no method to add an iproperty in Inventor 2020 vewrsion at least. Pass in the iproperty value to the parameter to update.
Sub Main()
' This assumes that currently active document is a part document.
Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
Dim oFullFileName As String = oPartDoc.FullFileName
Dim oPartCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
' Find Sketch named already For marking so the user can delete it
Return
End If
Next
' Select Face and Edges to place the textbox in a certain direction = Van JelteDejong Forum
' Add Sketch and set sketch origin point to the stopVertex of the FrontEdge, this is where the TextBox starts
' Check if the testVertex has positive coordinates = Van JelteDejong Forum
End If
' Creating Custom IProperty with filenumber in it calling it Tekeningnummer
' Get the Property ID For these custom iProperties From the model referenced By the view
Dim TekenNum As [Property] = oPartDoc.PropertySets.Item("Inventor User Defined Properties").Item("Tekeningnummer")
TekenNum.Value = (Left(ThisDoc.FileName(False),14))
' Creating a UserParameter Where the Tekeningnummer value Is put In
Dim PropValue As String = TekenNum.Value
' Updates the user-defined Text Parameter
TagName = PropValue
'Parameter Field (formatted text). Manually place a text box an parameter,
'Then extract Formatted Text from this Text Box
Dim sText As String = "<Parameter Resolved='True' ComponentIdentifier='" & oFullFileName & "' Name='TagName' Precision='3'>""</Parameter>"
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Else
End If
Dim dTextSize As Double = 0.4 ' value is in cm. equals .125 in
'Dim sTextFont As String = "SIMPLEX"
'Set the text box to Parameter field
oTextBox.FormattedText = sText
'==================== Creating an Objectcollection To be Marked ======================
Dim oSketchObjects As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
For Each oSketchText As Inventor.TextBox In oSketch.TextBoxes
Next
Dim oMarkFeatures As MarkFeatures = oPartCompDef.Features.MarkFeatures
' Get a mark style.
Dim oMarkStyle As MarkStyle = oPartDoc.MarkStyles.Item(1)
Dim oMarkDef As MarkDefinition = oMarkFeatures.CreateMarkDefinition(oSketchObjects, oMarkStyle)
Dim oMark As MarkFeature = oMarkFeatures.Add(oMarkDef)
Call ZoomAll
oPartDoc.Save
End Sub
Sub ZoomAll
' zoom all, this to be sure the part is in ISOmetrich position saved so it is ISO visible in explorer
End Sub
And here is how to test and retrieve a textbox formatted text.
Sub Main Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument Dim oFullFileName As String = oPartDoc.FullFileName Dim oPartCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface To Place Textbox") Dim oSketch As PlanarSketch = oPartCompDef.Sketches.Add(oFace, True) Dim oTG As TransientGeometry = ThisApplication.TransientGeometry Dim oTextBox As Inventor.TextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.3, 0.5),"Hello") Dim sText As String = "<Parameter Resolved='True' ComponentIdentifier='" & oFullFileName & "' Name='Tag' Precision='3'>""</Parameter>" oTextBox.FormattedText = sText 'Retrieve formatted text from an exisiting textbox 'RetrieveFormattedText() End Sub Sub RetrieveFormattedText() Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument Dim oPartCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition Dim oSketch As PlanarSketch = oPartCompDef.Sketches(1) Dim oTextBox As Inventor.TextBox = oSketch.TextBoxes(1) sFormattedText = InputBox("","FormattedText",oTextBox.FormattedText) End Sub
Hi Allen,
I' m sorry but I've tried your code but it does not seem to work.
I'm using Inventor 2023 maybe that is the case I don't know.
Also your test does not give me the reuslt I want.
I want to textbox to contain the Field from the Iprop not the text so I mean the field <Tekeningnummer>.
This way it updates when the field changes
See also the attached screenshots.
Hi There,
I finally figured it out. I have combined a part of the rule from another post;
How to assign a iProperty to a textbox in my title through VB
The ruleline by @WCrihfield does the trick 🙂 :
Dim sText As String sText = "<Property Document='Model' PropertySet='User Defined Properties' Property='Tekeningnummer' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}'>Tekeningnummer</Property>"
Now the "Tekeningnummer" as a Field is inserted in the textbox and I get what I want.
Many thanks to all of you, espacially mentioned @JelteDeJong and @A.Acheson
For you all to use and benifit from I've pasted the Rule for engraving below.
Hope you can use it and have fun with it 🙂
Last remark is that on some faces of the sheetmetal the text is placed not right but I hope to fix this in the future. For now I can work fine with it.
Sub Main() '===================== DECLERATIONS =============================== ' a reference to the currently active document. ' This assumes that it is a part document. Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument Dim oCompDef As PartComponentDefinition oCompDef = oPartDoc.ComponentDefinition ' Set a reference to the transient geometry object. Dim oTransGeom As TransientGeometry oTransGeom = ThisApplication.TransientGeometry Dim oPartCompDef As PartComponentDefinition oPartCompDef = ThisApplication.ActiveDocument.ComponentDefinition '===================Checking If the Custom Property has already been made in the part ================= 'Find Sketch named already For marking so the user can delete it For Each oSketchCheck As PlanarSketch In oPartCompDef.Sketches If oSketchCheck.Name = "MarkingSketch" Then MessageBox.Show("A sketch named " & oSketchCheck.Name & " already exists. Custom Iprop Tekeningnummer will be updated", "Controle op MarkingSketch") 'Updating Custom IProperty with filenumber in it calling it Tekeningnummer iProperties.Value("Custom", "Tekeningnummer") = ThisDoc.FileName(False) 'false = without extension iProperties.Value("Custom", "Tekeningnummer") = (Left(ThisDoc.FileName(False),14)) Return End If Next '================================================================================================================================================== 'Select Face and Edges to place the textbox in a certain direction = Van JelteDejong Forum Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface to Place Textbox") Dim oHorizontalEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select Horizontal Edge of Tekeningnummer on Face") Dim orignVertex As Vertex = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter, "Select Point (vertex) on the plane") Dim testVertex As Vertex = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter, "Select a 2nd Point (vertex) that is on a positive point in the sketch and not on the axes") 'Add Sketch and set sketch origin point to the stopVertex of the FrontEdge, this is where the TextBox starts Dim oSketch As PlanarSketch = oPartCompDef.Sketches.Add(oFace, False) oSketch.AxisEntity = oHorizontalEdge oSketch.OriginPoint = orignVertex oSketch.NaturalAxisDirection = True 'Check if the testVertex has positive coordinates = Van JelteDejong Forum Dim testPoint As Point2d = oSketch.ModelToSketchSpace(testVertex.Point) If (testPoint.X <= 0 Or testPoint.Y <= 0) Then oSketch.NaturalAxisDirection = False End If testPoint = oSketch.ModelToSketchSpace(testVertex.Point) Dim positiveQuadrantIsOnPlane = (testPoint.Y >= 0) ' ===================== Create a Custom Parameter in Iproperties "Tekeningnummer"====================== 'Creating Custom IProperty with filenumber in it calling it Tekeningnummer iProperties.Value("Custom", "Tekeningnummer") = ThisDoc.FileName(False) 'false = without extension iProperties.Value("Custom", "Tekeningnummer") = (Left(ThisDoc.FileName(False),14)) 'Creating a UserParameter Where the Tekeningnummer value Is put In Dim PropValue As String = iProperties.Value("Custom", "Tekeningnummer") 'updates the user-defined Text Parameter TagName = PropValue '================================ Create a textbox in the Sketch to place the Custom Iporperty Tekeningnummer ==================== ' Create Text With simple String As Input. Since this doesn't use ' any Text Overrides, it will Default To the active Text Style. Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry Dim sText As String sText = "<Property Document='Model' PropertySet='User Defined Properties' Property='Tekeningnummer' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}'>Tekeningnummer</Property>" Dim oTextBox As Inventor.TextBox If (positiveQuadrantIsOnPlane) Then oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.3, 0.5), sText) Else oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.3, -0.3), sText) End If 'Changing Font and/or size Dim dTextSize As Double dTextSize = 0.4 ' value is in cm. equals .125 in Dim sTextFont As String ' sTextFont = "SIMPLEX" oTextBox.FormattedText = "<StyleOverride Font = '" & sTextFont & "' FontSize = '" & dTextSize & "'>" & _ sText & "</StyleOverride>" '==================== Creating an Objectcollection to be Marked ====================== Dim oSketchObjects As ObjectCollection oSketchObjects = ThisApplication.TransientObjects.CreateObjectCollection ' Get all entities in the sketch Dim oSketchText As Inventor.TextBox For Each oSketchText In oSketch.TextBoxes oSketchObjects.Add(oSketchText) Next '==================== Creating the Mark on the textbox ====================== Dim oMarkFeatures As MarkFeatures oMarkFeatures = oCompDef.Features.MarkFeatures ' Get a mark style. Dim oMarkStyle As MarkStyle oMarkStyle = oPartDoc.MarkStyles.Item(1) ' Create mark definition. Dim oMarkDef As MarkDefinition oMarkDef = oMarkFeatures.CreateMarkDefinition(oSketchObjects, oMarkStyle) ' Create a mark feature. Dim oMark As MarkFeature oMark = oMarkFeatures.Add(oMarkDef) '==================== 'Naming the sketch And markfeature For detection In future oSketch.Name = "MarkingSketch" oMark.Name = "Gravering Tekeningnummer" Call ZoomAll oPartDoc.Save End Sub Sub ZoomAll 'zoom all, this to be sure the part is in ISOmetrich position saved so it is ISO visible in explorer ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute End Sub
hej 🙂
I've started writing my own rule for the same purpose and ran into exactly the same issue as you.
How do I get iProperties into a textbox that updates with changes?
Your rule is perfect for our case, and I just needed to make a few adjustments:
Instead of custom iProperties, I'm retrieving 'Part Number' and 'Revision Number'.
Here's how the changes would look, in case anyone needs it:
sText = "<Property Document='model' FormatID='{32853F0F-3444-11d1-9E93-0060B03C1CA6}' PropertyID='5' />" & " - " & "<Property Document='model' FormatID='{F29F85E0-4FF9-1068-AB91-08002B27B3D9}' PropertyID='9' />"
Hats off, and thanks for sharing the code!
