Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Insert a Custom Property (as a field) into a textbox which changes when filename changes
9 REPLIES 9
Message 1 of 10
jeanB99VC
1641 Views, 9 Replies
Hi There,
I want insert a Custom Property into a Textbox as a field, see below Screenshot.
In that way it will change as I change the part.
Goal: I want to put the filenumber (custom Iporperty) into a textbox as a field.
Then when I save the file as another number this field will update.
My Problem is that I don't know how to insert this field into the textbox.
The code that I have thisfar is:
Sub Main()
'===================== DECLERATIONS ===============================
 '  a reference to the currently active document.
 ' This assumes that it is a part document.
	    Dim oPartDoc As PartDocument
	    	oPartDoc = ThisApplication.ActiveDocument
		Dim oCompDef As PartComponentDefinition
			oCompDef = oPartDoc.ComponentDefinition
  ' Set a reference to the transient geometry object.
    	Dim oTransGeom As TransientGeometry
    		oTransGeom = ThisApplication.TransientGeometry
		Dim oPartCompDef As PartComponentDefinition
			oPartCompDef = ThisApplication.ActiveDocument.ComponentDefinition
		oModel=ThisDoc.ModelDocument
		'Creating Custom IProperty with filenumber in it calling it Tekeningnummer
			iProperties.Value("Custom", "Tekeningnummer") = ThisDoc.FileName(False) 'false = without extension
			iProperties.Value("Custom", "Tekeningnummer") = (Left(ThisDoc.FileName(False),14))
	'Get the Property ID For these custom iProperties From the model referenced By the view
		o_iPropID_1 = oModel.PropertySets.Item("Inventor User Defined Properties").Item("Tekeningnummer").PropId
'format the custom iproperty string and add the property ID
		oString1 = "<Property Document='model' PropertySet='User Defined Properties' " _
		&  "Property='FCE_PartNumber' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='" _
		& o_iPropID_1  & "'>FCE_PartNumber</Property><Br/>"
End Sub
Hope you can help me with this.
PS: This is to complete my engraving rule to automaticly update the engraving when copying the part to another part.
"Ilogic Rule To Mark Textbox on a face with a specific direction for Engraving
@JelteDeJong
Labels (3)
9 REPLIES 9
Message 2 of 10
A.Acheson
in reply to: jeanB99VC
You can added the iproperty by general text, see api sample for vba here for updating exisiting drawings.
Here is the ilogic version of the same code with a sub routine to retrieve an existing iprop formatted text.
Or the alternate method is to add it in the drawing template manually and then just change the iproperty by code. No need for the formatted text then.
Regards
Alan
Message 3 of 10
dgreatice
Why you need automation? this case is simple, just use leader note and assign it.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 4 of 10
jeanB99VC
in reply to: A.Acheson
Hi There,
I'm not talking about a drawing.
I want the textfield (Custom Property) to be placed in a sketch on the face of a sheetmetalpart as a field.
Then I can turn it into a mark for engraving. This rule has already been made in another post from me.
I don't understand the help in inventor itself
Goal: I'm looking for the specific method to insert the custom property as a field in the textbox on the face of a part.
@Ilogic Rule To Mark Textbox on a face with a specific direction for Engraving
@JelteDeJong
Message 5 of 10
A.Acheson
Ok I see it's a part. Your previous post is doing exactly that at this area of the code
Create a textbox in the Sketch to place the Iporp Tekeningnummer ====================
Once the textbox is created then set the formatted text like
oTextBox.FormattedText= oString1
Regards
Alan
Message 6 of 10
jeanB99VC
Hi Alan,
I'm sorry but I'm not sure what to do where to change what. I have the idea that I'm close but not close enough 🙂
Is it possible for you to change my rule below so the textbox is filled with the Field of the custom prop instead of the value.
That way if the part is saved as another name the textbox automaticly changes. That was my goal for this rule
I've pasted the rule for engraving below.
Thank you in advance !
Sub Main()
'Find Sketch named already For marking so the user can delete it
	For Each oSketchCheck As PlanarSketch In oPartCompDef.Sketches
		If oSketchCheck.Name = "MarkingSketch" Then
			MessageBox.Show("A sketch named " & oSketchCheck.Name & " already exists. Please Delete this sketch", "Controle op MarkingSketch")
			Return
		End If
	Next
'Select Face and Edges to place the textbox in a certain direction = Van JelteDejong Forum
Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface to Place Textbox")
Dim oHorizontalEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select Horizontal Edge of Tekeningnummer on Face")
Dim orignVertex As Vertex = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter, "Select Point (vertex) on the plane")
Dim testVertex As Vertex = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter, "Select a 2nd Point (vertex) that is on a positive point in the sketch and not on the axes")
'Add Sketch and set sketch origin point to the stopVertex of the FrontEdge, this is where the TextBox starts
Dim oSketch As PlanarSketch = oPartCompDef.Sketches.Add(oFace, False)
oSketch.AxisEntity = oHorizontalEdge
oSketch.OriginPoint = orignVertex
oSketch.NaturalAxisDirection = True
'Check if the testVertex has positive coordinates  = Van JelteDejong Forum
Dim testPoint As Point2d = oSketch.ModelToSketchSpace(testVertex.Point)
If (testPoint.X <= 0 Or testPoint.Y <= 0) Then
	oSketch.NaturalAxisDirection = False
End If
testPoint  = oSketch.ModelToSketchSpace(testVertex.Point)
Dim positiveQuadrantIsOnPlane = (testPoint.Y >= 0)
' ===================== Create a Custom Parameter in Iproperties "Tekeningnummer"======================
		'Creating a UserParameter Where the Tekeningnummer value Is put In
		Dim PropValue As String = iProperties.Value("Custom", "Tekeningnummer")
		'updates the user-defined Text Parameter
		TagName = PropValue
'================================ Create a textbox in the Sketch to place the Iporp Tekeningnummer ====================
		'     Create Text With simple String As Input.  Since this doesn't use
		'     any Text Overrides, it will Default To the active Text Style.
			Dim oTG As TransientGeometry
		    	oTG = ThisApplication.TransientGeometry
			Dim sText As String
		    	sText = TagName
			Dim oTextBox As Inventor.TextBox
					If (positiveQuadrantIsOnPlane) Then
						oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.3, 0.5), sText)
					Else
				oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.3, -0.3), sText)
			End If
'Changing Font and/or size
		Dim dTextSize As Double
			dTextSize = 0.4 ' value is in cm.  equals .125 in
		Dim sTextFont As String
'			sTextFont = "SIMPLEX"
			oTextBox.FormattedText = "<StyleOverride Font = '" & sTextFont & "' FontSize = '" & dTextSize & "'>" & _
				sText & "</StyleOverride>"
'==================== Creating an Objectcollection to be Marked ======================
    Dim oSketchObjects As ObjectCollection
    	oSketchObjects = ThisApplication.TransientObjects.CreateObjectCollection
    ' Get all entities in the sketch
	Dim oSketchText As Inventor.TextBox
    	For Each oSketchText In oSketch.TextBoxes
     	   oSketchObjects.Add(oSketchText)
	Next
'==================== Creating the Mark on the textbox  ======================
    Dim oMarkFeatures As MarkFeatures
    	oMarkFeatures = oCompDef.Features.MarkFeatures
' Get a mark style.
    Dim oMarkStyle As MarkStyle
    	oMarkStyle = oPartDoc.MarkStyles.Item(1)
' Create mark definition.
	Dim oMarkDef As MarkDefinition
		oMarkDef = oMarkFeatures.CreateMarkDefinition(oSketchObjects, oMarkStyle)
' Create a mark feature.
	Dim oMark As MarkFeature
		oMark = oMarkFeatures.Add(oMarkDef)
'Naming the sketch And markfeature For detection In future
		oSketch.Name = "MarkingSketch"
		oMark.Name = "Gravering Tekeningnummer"
Call ZoomAll
oPartDoc.Save
End Sub
Sub ZoomAll
'zoom all, this to be sure the part is in ISOmetrich position saved so it is ISO visible in explorer
	ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute
End Sub
Message 7 of 10
A.Acheson
Here is what is working. The parameter field is added via formatted text. There is no method to add an iproperty in Inventor 2020 vewrsion at least. Pass in the iproperty value to the parameter to update.
Sub Main()
	' This assumes that currently active document is a part document.
	Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
	Dim oFullFileName As String = oPartDoc.FullFileName
	Dim oPartCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
	' Find Sketch named already For marking so the user can delete it
			Return
		End If
	Next
	' Select Face and Edges to place the textbox in a certain direction = Van JelteDejong Forum
	' Add Sketch and set sketch origin point to the stopVertex of the FrontEdge, this is where the TextBox starts
	' Check if the testVertex has positive coordinates  = Van JelteDejong Forum
	End If
	' Creating Custom IProperty with filenumber in it calling it Tekeningnummer
	' Get the Property ID For these custom iProperties From the model referenced By the view
	Dim TekenNum As [Property] = oPartDoc.PropertySets.Item("Inventor User Defined Properties").Item("Tekeningnummer")
	TekenNum.Value = (Left(ThisDoc.FileName(False),14))
	' Creating a UserParameter Where the Tekeningnummer value Is put In
	Dim PropValue As String = TekenNum.Value
	' Updates the user-defined Text Parameter
	TagName = PropValue
	'Parameter Field (formatted text). Manually place a text box an parameter,
	'Then extract Formatted Text from this Text Box
	Dim sText As String = "<Parameter Resolved='True' ComponentIdentifier='" & oFullFileName & "' Name='TagName' Precision='3'>""</Parameter>"
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Else
	End If
	Dim dTextSize As Double = 0.4 ' value is in cm.  equals .125 in
	'Dim sTextFont As String = "SIMPLEX"
	'Set the text box to Parameter field
	oTextBox.FormattedText = sText
	'==================== Creating an Objectcollection To be Marked ======================
	Dim oSketchObjects As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	For Each oSketchText As Inventor.TextBox In oSketch.TextBoxes
	Next
	Dim oMarkFeatures As MarkFeatures = oPartCompDef.Features.MarkFeatures
	' Get a mark style.
	Dim oMarkStyle As MarkStyle = oPartDoc.MarkStyles.Item(1)
	Dim oMarkDef As MarkDefinition = oMarkFeatures.CreateMarkDefinition(oSketchObjects, oMarkStyle)
	Dim oMark As MarkFeature = oMarkFeatures.Add(oMarkDef)
	Call ZoomAll
	oPartDoc.Save
End Sub
Sub ZoomAll
	' zoom all, this to be sure the part is in ISOmetrich position saved so it is ISO visible in explorer
End Sub
And here is how to test and retrieve a textbox formatted text.
Sub Main
	Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface To Place Textbox")
	Dim oSketch As PlanarSketch = oPartCompDef.Sketches.Add(oFace, True)
	Dim oTextBox As Inventor.TextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.3, 0.5),"Hello")
	Dim sText As String = "<Parameter Resolved='True' ComponentIdentifier='" & oFullFileName & "' Name='Tag' Precision='3'>""</Parameter>"
	'Retrieve formatted text from an exisiting textbox
	'RetrieveFormattedText()
End Sub
Sub RetrieveFormattedText()
	Dim oSketch As PlanarSketch = oPartCompDef.Sketches(1)
	Dim oTextBox As Inventor.TextBox = oSketch.TextBoxes(1)
	sFormattedText = InputBox("","FormattedText",oTextBox.FormattedText)
End Sub
Regards
Alan
Message 8 of 10
jeanB99VC
Hi Allen,
I' m sorry but I've tried your code but it does not seem to work.
I'm using Inventor 2023 maybe that is the case I don't know.
Also your test does not give me the reuslt  I want.
I want to textbox to contain the Field from the Iprop not the text so I mean the field <Tekeningnummer>.
This way it updates when the field changes
See also the attached screenshots.
Message 9 of 10
jeanB99VC
Hi There,
I finally figured it out. I have combined a part of the rule from another post;
How to assign a iProperty to a textbox in my title through VB
The ruleline by @WCrihfield does the trick 🙂 :
Dim sText As String
		    	sText = "<Property Document='Model' PropertySet='User Defined Properties' Property='Tekeningnummer' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}'>Tekeningnummer</Property>"
Now the "Tekeningnummer" as a Field is inserted in the textbox and I get what I want.
Many thanks to all of you, espacially mentioned @JelteDeJong and @A.Acheson
For you all to use and benifit from I've pasted the Rule for engraving below.
Hope you can use it and have fun with it 🙂
Last remark is that on some faces of the sheetmetal the text is placed not right but I hope to fix this in the future. For now I can work fine with it.
Sub Main()
'===================Checking If the Custom Property has already been made in the part =================
			MessageBox.Show("A sketch named " & oSketchCheck.Name & " already exists. Custom Iprop Tekeningnummer will be updated", "Controle op MarkingSketch")
'Updating Custom IProperty with filenumber in it calling it Tekeningnummer
			Return
		End If
	Next
End If
		TagName = PropValue
'================================ Create a textbox in the Sketch to place the Custom Iporperty Tekeningnummer ====================
			Dim sText As String
					Else
			End If
	Next
' Get a mark style.
Call ZoomAll
oPartDoc.Save
End Sub
Sub ZoomAll
End Sub
Message 10 of 10
n_krisch
hej 🙂
I've started writing my own rule for the same purpose and ran into exactly the same issue as you.
How do I get iProperties into a textbox that updates with changes?
Your rule is perfect for our case, and I just needed to make a few adjustments:
Instead of custom iProperties, I'm retrieving 'Part Number' and 'Revision Number'.
Here's how the changes would look, in case anyone needs it:
sText = "<Property Document='model' FormatID='{32853F0F-3444-11d1-9E93-0060B03C1CA6}' PropertyID='5' />" & " - " & "<Property Document='model' FormatID='{F29F85E0-4FF9-1068-AB91-08002B27B3D9}' PropertyID='9' />"
Hats off, and thanks for sharing the code!
