I Have a assembly and I just one to change part number form 00 - 99, with order from up to down (please look at the picture).
I tried the code , but it open all file in assembly with a random order, it's hard to fill all part number. In addition, is there possible to access just top level parts? (Not the parts inside level 2-assembly)
openDoc = ThisApplication.ActiveDocument
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
Next
Please help.
What do you mean when changing par number?
From what I understand :
Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition Dim oOccurrence As ComponentOccurrence Dim iInteger As Integer = 0 Dim oStr As String For Each oOccurrence In oAsmCompDef.Occurrences iInteger = iInteger + 1 oStr = iInteger oOccurrence.Name = oStr Next
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"I'll add the 00.
Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition Dim oOccurrence As ComponentOccurrence Dim iInteger As Integer = 0 Dim oStr As String For Each oOccurrence In oAsmCompDef.Occurrences iInteger = iInteger + 1 If iInteger < 10 Then oStr = "0" & iInteger Else If iInteger > 9 Then oStr = iInteger End If oOccurrence.Name = oStr Next
If this post helped out in any way to solve your question, please drop a "Like"thank you for reply.
I meant I wanted to set part number in order (from up to down). Like 00.01, 00.02, 00.03 ...; But my code access to parts randomly, doesn't go from up to down, and it accesses to all assembly documents and the parts inside them too. I just want to access to all parts on top-level .
Hi @Anonymous . Try this:
Dim oDoc As AssemblyDocument = ThisAssembly.Document Dim newPartNum As Integer = 0 Dim asmDef = oDoc.ComponentDefinition For Each occ As ComponentOccurrence In asmDef.Occurrences Dim occDoc As Document = occ.Definition.Document newPartNum = newPartNum + 1 occDoc.PropertySets("Design Tracking Properties")("Part Number").Value = "Text " & newPartNum & " AnotherText" Next
After running the code, right click the parts and check the iproperties.
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Property.set_Value(Object )
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
