Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
iLogic to tick Excel Tick box
2 REPLIES 2
youann21700
167 Views, 2 Replies
I am using a form to complete an excel sheet. Currently I am using True/False labels in certain boxes, ideally I would use tick boxes. Is it possible to get iLogic to operate excel tick boxes?
2 REPLIES 2
A.Acheson
in reply to: youann21700
Hi @youann21700
Here is a VBA method to read/write to excel cell checkbox.  Assuming this is what you have a checkbox for manual operation on an excel sheet and you want to programically change?
Are you starting from a local I logic form? If so you can just use the parameters true false status to trigger a rule.N the rule you need to open excel, find the check box cell and change the checkbox status.
If this solved a problem, please click (accept) as solution.ā€Œā€Œā€Œā€Œ
Or if this helped you, please, click (like)ā€Œā€Œ
Regards
Alan
Technology Administrators
