I am using a form to complete an excel sheet. Currently I am using True/False labels in certain boxes, ideally I would use tick boxes. Is it possible to get iLogic to operate excel tick boxes?
Solved by A.Acheson. Go to Solution.
maybe you can start from:
https://forums.autodesk.com/t5/inventor-programming-ilogic/create-form-with-ilogic/m-p/12435474
Hi @youann21700
Here is a VBA method to read/write to excel cell checkbox. Assuming this is what you have a checkbox for manual operation on an excel sheet and you want to programically change?
Are you starting from a local I logic form? If so you can just use the parameters true false status to trigger a rule.N the rule you need to open excel, find the check box cell and change the checkbox status.
