iLogic to set filename.
Good day,
I have created an iPart that I use to create a part with a number of different parameters, i.e. height, width, angle, number of certain occurences, etc. Its actually a fairly simplistic setup and works well. I have now created a form to drive the variables in a single popup, which also works well.
So my next step is to add an entry on the form where I can specify the file name the new part should have. Currently I do a file saveas manually and save the file in the following format - PART - Height x Angle x Width x Number and then place this in an assembly. Most of the variance is in the height and number, angle and width generally do not change very often.
Unfortunately I cannot share anything due to NDA restrictions but I think my description should do the trick.
However, I cannot find a way to set the filename either as a rule or as an option within the form environment. Can it be done even?
I would appreciate any thoughts on this.
Regards
Kobus
