Hello.
Im working on this code to suppress components with BOM structure is set to reference.
It does'nt work.
Need help please.
Thank you.
Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition Dim CompOcc As ComponentOccurrence For Each CompOcc In oAsmCompDef.Occurrences If CompOcc.Definition.BOMStructure.kReferenceBOMStructure = True Then CompOcc.IsActive = False End If Next
Solved by marcin_otręba. Go to Solution.
Solved by JelteDeJong. Go to Solution.
try this:
Dim oAsmCompDef As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition For Each CompOcc As ComponentOccurrence In oAsmCompDef.Occurrences ' go to next occurence if its already suppressed If CompOcc.Suppressed = True Then Continue For End If 'suppress when the bom structure is set in the part/assembly If CompOcc.Definition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then CompOcc.Suppress() End If 'suppress when the bom structure is set in the assembly occurrence If (CompOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure) Then CompOcc.Suppress() End If Next
Jelte de Jong
Blog: hjalte.nl - github.com
try:
Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition Dim CompOcc As ComponentOccurrence For Each CompOcc In oAsmCompDef.Occurrences If CompOcc.BOMStructure = kReferenceBOMStructure Then CompOcc.Suppress End If Next
