Ilogic Suppress components if BOM structure is set to reference
2 REPLIES 2
561 Views, 2 Replies
Hello.
Im working on this code to suppress components with BOM structure is set to reference.
It does'nt work.
Need help please.
Thank you.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim CompOcc As ComponentOccurrence
For Each CompOcc In oAsmCompDef.Occurrences
	If CompOcc.Definition.BOMStructure.kReferenceBOMStructure = True Then
		CompOcc.IsActive = False
	End If
Next
Tags (3)
Labels (1)
2 REPLIES 2
JelteDeJong
try this:
Dim oAsmCompDef As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
For Each CompOcc As ComponentOccurrence In oAsmCompDef.Occurrences
	' go to next occurence if its already suppressed
	If CompOcc.Suppressed = True Then
		Continue For
	End If
	'suppress when the bom structure is set in the part/assembly
	If CompOcc.Definition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
		CompOcc.Suppress()
	End If
	'suppress when the bom structure is set in the assembly occurrence
	If (CompOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure) Then
		CompOcc.Suppress()
	End If
Next
Jelte de Jong
Blog: hjalte.nl - github.com
marcin_otręba
try:
	If CompOcc.BOMStructure = kReferenceBOMStructure Then
		CompOcc.Suppress
	End If
Next
Technology Administrators
