Hi
I've come up with the following iLogic rule:
oDoc = ThisDoc.Document aDoc = ThisApplication.ActiveDocument oFilePath = Left(aDoc.FullDocumentName, InStrRev(aDoc.FullDocumentName, "\")) SubFolder = "\Koost\" oPath = oFilePath & SubFolder oName = "Koost" oNR = "1" If Not System.IO.Directory.Exists(oPath) Then System.IO.Directory.CreateDirectory(oPath) End If oProject_Filenames = System.IO.Directory.GetFiles(oPath) For Each oOpenFiles As String In oProject_Filenames If oOpenFiles.Contains(oName) Then oNR = oNR + 1 End If Next If oNR < 10 Then oNR = "00" + CStr(oNR) ElseIf oNR < 100 Then oNR = "0" + CStr(oNR) Else oNR = CStr(oNR) End If oType = ".ipt" oFullFileName = oPath & oName & oNR & oType oDoc.SaveAs(oFullFileName, False)
Everything seems to work fine, untill i use more than one part in an assembly. If i close and reopen my assembly, somehow all parts, what i have placed after first item, are replaced with same part. Watch the video. Any ideas?
Hi
This problem still exists. Not all the time but most of time. I have tried to find pattern when and what conditions it happen but with no luck.
Do anybody have any idea what causing this behavior?
