Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Automated section views in drawing
12 REPLIES 12
Message 1 of 13
TechInventor20
896 Views, 12 Replies
Currently i'm working on a set of codes in Ilogic that automate a drawing. But I got stuk on the part where I make the section views.
The work flow is;
- get some workpoints in the baseview (Topview)
- create lines between them
- Make the section views
- (part that does work but not all the way) rotate the section views.
This is where I start with;
This is afther the section views are created;
Afther the rotating the section views are standing upside down or have the direction not in the right way (see picture below);
This is how the direction of the section view should look like but I didn't figure out how to get there.... ( i want it to go counter clockwise);
The code i have for rotating the view is this. maybe you can tweak it or use the variables etc. etc.
Dim oDrawingDocument As DrawingDocument = ThisServer.ActiveDocument
Dim oSheet As Sheet = oDrawingDocument.ActiveSheet
Dim oView2 As DrawingView = ActiveSheet.View("Aanzicht1").View
Dim oAssemblyDoc2 As AssemblyDocument = oView2.ReferencedDocumentDescriptor.ReferencedDocument
Dim oOccs2 As ComponentOccurrences
oOccs2 = oAssemblyDoc2.ComponentDefinition.Occurrences
Dim oOcc2 As ComponentOccurrence
For Each oOcc2 In oOccs2
	Totaltel = Totaltel + 1
Next
Dim oOccs As ComponentOccurrences
oSketches = oView2.Sketches
'Variabelen------------------------
Dim Tel As Integer = 1 'als aantal schetsen/views
Dim Row As Integer = 4 'Rij voor aantal graden (excel)
For Each osketch In oSketches
Dim Viewletter As String = Chr(64 + Tel) 'Van getal naar letter (Voor sectionview naam.)
Dim oView As DrawingView = ActiveSheet.View(Viewletter).View
Dim oAssemblyDoc As AssemblyDocument = oView.ReferencedDocumentDescriptor.ReferencedDocument
oOccs = oAssemblyDoc.ComponentDefinition.Occurrences
Dim oOcc As ComponentOccurrence
Dim Oviewtje As DrawingView
'Oviewtje = oSheet.DrawingViews.Item(2)
Oviewtje = ActiveSheet.View(Viewletter).View
Dim Degrees As Integer = GoExcel.CellValue("C:\Users\Thomas\Desktop\TANK 3D.xlsx", "Romp", "D" & Row)
Degrees = 360 - Degrees + 90
If Degrees > 360 Then
	Degrees = Degrees - 360
rotatie_degrees = (Oviewtje.Rotation / PI * 180)
If rotatie_degrees*-1 = Degrees Or rotatie_degrees = Degrees Then
	Else
Oviewtje.RotateByAngle(Degrees * (PI / 180), True)
'iLogicVb.RunRule("TESTING_EXTRA")
Dim teller As Integer = 1
For Each oOcc In oOccs
	Dim oComponentOcc As ComponentOccurrence = oAssemblyDoc.ComponentDefinition.Occurrences.Item(teller)
	If oComponentOcc.Name = "KW-02-00:1" Then
	xComponentOcc = oComponentOcc.Name.Replace(":1", "")
	For Each Nozzle1 As Document In oAssemblyDoc.ReferencedDocuments
	Dim Nozzle2 As String = Nozzle1.DisplayName
	If Right(Nozzle2,3) = "ipt" Then
	xNozzle = Nozzle2.Replace(".ipt", "")
	Else
	xNozzle = Nozzle2.Replace(".iam", "")
''	Nozzle = oAssemblyDoc.ReferencedDocuments.Item(2)
''	Totaltel = Totaltel - 1
	If xNozzle = xComponentOcc Then
		Nozzle = Nozzle1
	Next
	Dim oWorkPoint1 As WorkPoint = Nozzle.ComponentDefinition.WorkPoints.Item(1)
	oComponentOcc.CreateGeometryProxy(oWorkPoint1, oWorkPointProx1)
	Oviewtje.SetIncludeStatus(oWorkPointProx1, True)
	teller = teller + 1
Next
teller = 1
	If xComponentOcc = "KW-06-" & Tel Then
	Else
		Nozzle = Nozzle1
	Next
	Dim oWorkPoint2 As WorkPoint = Nozzle.ComponentDefinition.WorkPoints.Item(1)
	oComponentOcc.CreateGeometryProxy(oWorkPoint2, oWorkPointProx2)
	Oviewtje.SetIncludeStatus(oWorkPointProx2, True)
	teller = teller + 1
Next
''	Tel = Tel + 1
'	If Left(Nozzle.displayname, 5) = "KW-06" Then
'	End If
'	If Left(Nozzle.displayname, 5) = "KW-02" Then
'	Dim oWorkPoint2 As WorkPoint = Nozzle.ComponentDefinition.WorkPoints.Item(1)
'	oComponentOcc.CreateGeometryProxy(oWorkPoint2, oWorkPointProx2)
'	oView.SetIncludeStatus(oWorkPointProx2, True)
'	End If
Dim oCenterMark1 As Centermark
Dim oCenterMark2 As Centermark
Dim oCenterMark As Centermark
For Each oCenterMark In oSheet.Centermarks
        If oCenterMark.Attached Then
            If oCenterMark.AttachedEntity Is oWorkPointProx1 Then
                oCenterMark1 = oCenterMark
			ElseIf oCenterMark.AttachedEntity Is oWorkPointProx2 Then
                oCenterMark2 = oCenterMark
    Next
Dim oViewSection As SectionDrawingView
'oViewSection = oSheet.DrawingViews.Item(2)
oViewSection = ActiveSheet.View(Viewletter).View
If oCenterMark1.Position.X > oCenterMark2.Position.X Then
oViewSection.ReverseDirection
Hoogte_nozzle = GoExcel.CellValue("C:\Users\Thomas\Desktop\TANK 3D.xlsx", "Romp", "F" & Row)
If Hoogte_nozzle - Hoogte_nozzle / 4 < oCenterMark2.Position.X*10 And oCenterMark2.Position.X*10 < Hoogte_nozzle + Hoogte_nozzle / 4 Then
	Else
		Oviewtje.RotateByAngle(Pie, True)
oView.SetIncludeStatus(oWorkPointProx1, False)
oView.SetIncludeStatus(oWorkPointProx2, False)
Tel = Tel + 1
Row = Row + 1
Next
I hope someone could help me and maybe have some fun with it.
@JelteDeJong
12 REPLIES 12
Message 2 of 13
The only thing that I need to get fixed is that the direction of the section view is in the right way and that the view is rotated like i showed in the pictures above. The rotation part works but not if the direction is reversed....
Message 3 of 13
Stakin
in reply to: TechInventor20
Are you want to add section as this way?
Message 4 of 13
TechInventor20
in reply to: Stakin
Hi stakin,
That is indeed what I'm looking for.
I have this rule that makes a section view of every sketch line in the drawing.
Afther running that rule i get the sectionviews but some of them are to the wrong direction. (see picture below)
Green is good direction and purple is the wrong direction.
Now i am trying to change that but first I have to rotate every view. This because that looks much nicer. otherwise it looks like this;
and i want them all  to align
Message 5 of 13
Stakin
the section direction is depend on the position of the section view
suggest you to put the section view to the temp position to be make a correct section direction
and then  rotate the view and  move it  to you want.
Tags (1)
Message 6 of 13
TechInventor20
in reply to: Stakin
And how do you see that? because the section views that i make are in random order.
Message 7 of 13
Stakin
DrawingViews.AddSectionView( ParentView As DrawingView, SectionLineSketch As DrawingSketch, Position As Point2d, ViewStyle As DrawingViewStyleEnum, [Scale] As Variant, [ShowLabel] As Boolean, [Name] As String, [Reserved] As Boolean, [FullDepth] As Boolean, [SectionDepth] As Variant ) As SectionDrawingView
The placement position determines the view direction.
The placement point is to the left of the section line and the section direction is to the left
Otherwise, vice versa
test it.
Message 8 of 13
TechInventor20
in reply to: Stakin
That part i'd understand, but how do i know wich one is to the left and to the right? how can i know that coordinates?
Message 9 of 13
Stakin
You can use the angle between the Y axis of the view and your section line
As your instance,it maybe
Dim oP1 As Point2d  ' Section Line Point in the cylinder
Dim oP2 As Point2d  'Section Line Point the cylinder outer point
Dim oP3 As Point2d 'the section view first place position point
Dim oV1 As Vector2d
Dim oV2 As Vector2d
oV1 = ThisApplication.TransientGeometry.CreateVector2d(oP2.X - oP1.X, oP2.Y - oP1.Y)
oV2 = ThisApplication.TransientGeometry.CreateVector2d(0, If(oP1.X=0,1,Sign(oP1.X)))
oV1.AddVector(oV2)
oV1.ScaleBy(0.5)
oP3 = oP1.Copy
oP3.TranslateBy(oV1)
try it,untested,it may be cann't meet your demand
Message 10 of 13
TechInventor20
in reply to: Stakin
Thankyou for your time,
I will test this next week. im very busy right now. So youll hear from me soon
Message 11 of 13
Stakin
in reply to: Stakin
Try this,
Dim oP1 As Point2d
Dim oP2 As Point2d
Dim oV1 As Vector2d
Dim oV2 As Vector2d
oV2 = ThisApplication.TransientGeometry.CreateVector2d(0, If(oP2.X=0,IIf(oP2.Y>=0,1,-1),Sign(oP2.X))*oV1.Length)
oV1.AddVector(oV2)
oV1.ScaleBy(0.5)
Dim oP3 As Point2d
oP3 = ThisApplication.TransientGeometry.CreatePoint2d((oP2.X + oP1.X)/2, (oP2.Y + oP1.Y)/2)
Message 12 of 13
TechInventor20
in reply to: Stakin
Morning,
Sorry I was occupied untill now, I tested it in a new ilogic rule, but I get the error message; "Object reference not set to an instance of an object."
How do I implement this in my rule?
Message 13 of 13
Stakin
Dim oP1 As Point2d 'sectionline First point inside the cylinder
Dim oP2 As Point2d 'sectionline second point outside the cylinder
Dim oV1 As Vector2d
Dim oV2 As Vector2d
oV1.AddVector(oV2)
oV1.ScaleBy(0.5)
Dim oP3 As Point2d
Add this code snippet to your rule of create section view
